Bad water leak & problem with battery not holding charge!
Old May 28, 2020 | 02:05 PM
Mikki LaCombe's Avatar
4th Gear
Unhappy Bad water leak & problem with battery not holding charge!
Need a reputable mechanic near me that can repair bad water leak & problem with the battery not holding charge.
2000 Acura 3.2 TL - New battery, Recent oil change, EGR Valve Replaced
Lyman, SC
Old May 28, 2020 | 02:32 PM
you'll have to be our eyes so we can help you diagnose where the water is coming from. If you've replaced the battery and still having an issue, it could be the alternator not properly charging the battery or you could have a parasitic draw.
Old May 28, 2020 | 08:05 PM
4th Gear
Unhappy
Hi, thoiboi & thanks for replying. What is a "parasitic draw"? The alternator was checked & I was told that it was ok. The water leak started small, months ago, & got worse and worse till a flood of water was building from front to back. It's been to 2 different mechanics, 3 different times & no one could tell me what was the problem, or how to fix it. I'm desperate & need help, please.
Old May 30, 2020 | 03:19 PM
wng's Avatar
wng
Parasitic draw is something drawing power even when the car is off. Could be an aftermarket accessory (dashcam, backup camera, radio, etc.) that is wired to get power all the time instead of only when key is in accessory position. Is your car stock or have things been changed/added?
You need to be more specific about where the water starts and where it appears. Does it only appear on the flooring? No water on the doors, seats, front/rear dash?
cipdagr3at
Dec 28, 2015 10:38 AM
o1s
Oct 22, 2011 09:21 PM
gilgameshx
Jul 25, 2011 10:45 AM
mickey513
1G TSX Problems & Fixes
50
Sep 29, 2008 11:21 PM
euroStyle
Oct 22, 2005 09:17 PM
