Bad water leak & problem with battery not holding charge!
Need a reputable mechanic near me that can repair bad water leak & problem with the battery not holding charge.
2000 Acura 3.2 TL - New battery, Recent oil change, EGR Valve Replaced
Lyman, SC
Lyman, SC
you'll have to be our eyes so we can help you diagnose where the water is coming from. If you've replaced the battery and still having an issue, it could be the alternator not properly charging the battery or you could have a parasitic draw.
Parasitic draw is something drawing power even when the car is off. Could be an aftermarket accessory (dashcam, backup camera, radio, etc.) that is wired to get power all the time instead of only when key is in accessory position. Is your car stock or have things been changed/added?
You need to be more specific about where the water starts and where it appears. Does it only appear on the flooring? No water on the doors, seats, front/rear dash?
