Bad ignition relay?
Old May 23, 2026 | 08:54 PM
E_S.0's Avatar
Bad ignition relay?
Hi,
was running errands the other day all over town and stopped at a friends house for a little while. Got back in my 2002 TL and the car did not even crank after multiple attempts. Had to leave it there for a couple hours until I came back trying to diagnose it. While I was under the steering column I tapped on what I assumed to be the ignition/starter relay with my phone and it worked? Got it back home and removed what I tapped on and it turned out to be the turn signal relay. I repeatedly started the car on and off again and out of the 8-9 or so times that I did, it failed once. I have no idea what is causing this, really need help because I don't want it to fail when I'm not in town.
Old May 23, 2026 | 11:31 PM
jmk2003's Avatar
Starter. Same thing happened to me a few years ago. Carry a hammer/pipe n your trunk. Next time it happens, hammer the side of the starter. It gets the starter off the ‘dead spot’ and it will start. Old Chevy trick.
Old May 25, 2026 | 12:51 AM
E_S.0's Avatar
Sounds simple enough, thank you
cartryhard
1G RL (1996-2004)
Mar 23, 2024 10:35 AM
Waukesha
Aug 1, 2021 03:22 PM
Sean Hedgecroft
Jul 12, 2020 02:05 PM
MyGuti
Jun 19, 2019 11:50 AM
Zerostatic
Nov 26, 2002 08:33 PM
