Bad Idle
Old 09-24-2009, 04:45 PM
4th Gear
herodecbr's Avatar
Bad Idle
hello all;
I have a 1999 Acura TL with about 145,000 on her. I have tried several times to reset the Idle through the 10 minute ECU idle trick to no avail. It idles from about 1,000 to 2,000. when in park or neutral. in drive it idles steady but quite high around 1,500. Trade in value for this beast is 3,000 dinero. So I guess I will take it to Mr Acura dealer for a diagnostic check. any one have any Ideas what could be wrong?
Old 09-25-2009, 08:35 AM
NSXNEXT's Avatar
Received 1,080 Likes on 661 Posts
Are you saying the idle fluctuates (goes up and down) when in park or neutral?
If so, clean or replace the idle air control valve (IACV). It's attached to the throttle body and can be removed and cleaned with carb cleaner.
Personally with that many miles and considering you've probably never had it cleaned before, I'd just replace it.
Old 09-27-2009, 08:49 PM
4th Gear
herodecbr's Avatar
bad Idle reply
Thanks I have the car dropped of at acura right now. if They can't fix it for less than 200.00 I will change out the IACV myself. Too bad i didn't wait a little longer for your reply!!!!
Old 09-27-2009, 09:53 PM
No He Can't
6MTUA5's Avatar
It's like a 30 minute fix to clean it out. Either way, you are probably going to have to pay some sort of diagnostic fee now.
Old 09-28-2009, 08:02 PM
4th Gear
herodecbr's Avatar
ok thanks MT might start on it tomorrow
DerrickW
11-15-2015 05:52 PM
012TL-GLM
10-05-2015 06:32 AM
Skirmich
10-01-2015 12:59 PM
mdlex389
4G TL Problems & Fixes
09-28-2015 06:29 PM
prbori
09-27-2015 01:37 AM
Quick Reply: Bad Idle
