bad gas mileage?
Old Feb 20, 2012 | 08:37 PM
inspire86's Avatar
bad gas mileage?
Wassup guys..my question is I just fill up my tank on Sunday night and today my tank is half way and I only driven 70 miles..is this normal or I have bad gas mileage
Old Feb 20, 2012 | 08:50 PM
csmaan12's Avatar
POWER!!
Well how was your driving? Did you WOT a lot? At the halfway mark I usually get between 120-130 miles.
Old Feb 20, 2012 | 09:01 PM
inspire86's Avatar
Nope I don't I drive slow mostly cuz my tl is drop
Old Feb 20, 2012 | 09:30 PM
csmaan12's Avatar
POWER!!
Hmm in that case, I'm not sure what would be the cause of this. Some things I can think of are not using 93 Premium fuel, vac leak, maybe needle is inaccurate. However I'll let someone more knowledgeable chime in, because I really am unsure.
What you can do is, go fill it back up to full, and see if it does it again.
Old Feb 20, 2012 | 10:32 PM
01tl4tl's Avatar
how fast does it usually go down?
is the drop new? new sticky tires- wide tires..
going slow hurts mileage- the TL needs some rpm -- 2500-3000 to be in the powerband for upshifting
what else has changed- work done on the car?
tire pressures?
Old Feb 20, 2012 | 10:34 PM
01tl4tl's Avatar
over 4500 rpm is vtec mode where it runs like,,and sucks gas like its a V-8 engine!
Old Feb 20, 2012 | 10:41 PM
nsnrider's Avatar
70 for half a tank, so 140 miles on a full tank of gas? if that's accurate then i'd say you're running very rich.
Old Feb 21, 2012 | 05:59 AM
inspire86's Avatar
All I did to the car is..remove intake resonator,lower car with ff1 coilovers..and i did use my heat here and there but I still feel like I should get more than 70 miles on a half tank..
Old Feb 21, 2012 | 07:01 AM
inspire86's Avatar
And also i change my rear driver side tire with a used tire
Old Feb 21, 2012 | 11:18 AM
01tl4tl's Avatar
chances are its a false reading
many have come on here with the same complaint,,only to find the rest of the tank lasted closer to its normal ~300 miles to the low fuel light (3 gal remaining)
I would seafoam the gas for sure, ck a spark plug or 2, replace if over 60-70kmiles on them, use NGK Iridium
Seafoam the TB, ck engine air filter and tire pressures
back when I got the new suspension and tires,,a few tanks were used quickly ~in the testing~
that cool sound it makes with the res removed means you are in vtec,,stop that!
Old Feb 21, 2012 | 05:28 PM
inspire86's Avatar
I change my spark plugs and air filter less than 10k miles ago and i seafoam my car yesturday..I'm just gonna wait til its empty and fill it up again and see..I keep you guys updated
Old Feb 22, 2012 | 12:57 AM
01tl4tl's Avatar
are you running the correct NGK spark plugs? about 8 dollars each?
how did you seafoam?
manifold vac method with the after drive to blow out the crud = eats a lot of fuel
expect lowered mileage as the cleaning process continues thru a tank.
DO the gas tank method of 1 can to just under half tank
a year old engine air filter can be restricted
ck the cabin filter for proof of that!
Old Feb 22, 2012 | 01:05 AM
mikefd417's Avatar
6th Gear
do the spark plug make a big difference ?
Old Feb 22, 2012 | 06:04 PM
inspire86's Avatar
Yes I used the correct plugs and I did seafoam thru the manifold vac..I always used Oem parts..
Old Feb 22, 2012 | 07:26 PM
tOny3's Avatar
My , ive tested my car multiple times. My TL is a damn gas guzzler with CITY miles, but with HIGHWAY miles its great. Just going 14miles city miles, constantly on the gas and brake knocks off 2 notches of gas for me. I pump premium also, Yea it sucks but theres nothing i can really do about it with city miles. Just gotta deal with it
Old Feb 23, 2012 | 06:52 AM
Skirmich's Avatar
Wierd my TL do 22 to 25mpg on City, But then Again my Engine isnt quite Stock.
But it wasnt a Gas Guzzler even when Stock.. Did most of the time 19 to 22mpgs.. My Reserve (When Gas Light comes On) is Insane I do like 55miles with it.
Old Feb 23, 2012 | 08:41 AM
tOny3's Avatar
Only mods i have
K&N Intake Filter
Intake Res Delete
Mid Muff Delete
TSUDO Axlebacks
K-Sports Coils
Old Feb 23, 2012 | 11:35 AM
inspire86's Avatar
On my first half tank I get about 70 miles..on my second half tank i get about 130 miles,its pretty weird..I just pour a quarter bottle of seafoam into my tank yesturday
Old Feb 24, 2012 | 09:48 AM
01tl4tl's Avatar
thats not enough seafoam --you want `2 ounces per gallon of fuel` for cleaning strength
= 1 can to just under half a tank of gas/ 8 gallons
and midyear run 1 oz per gal as maitenance dose = 1 can in just under full tank
manifold vac port 1/3- 1/2 can
Old May 9, 2012 | 06:00 PM
Homemade's Avatar
My 1st half goes by super fast then the rest is slow... just like every honda/acura in my opinion
Old May 9, 2012 | 07:20 PM
zmwang's Avatar
first half is ard 6-7 gal only
Skirmich
Oct 1, 2015 12:59 PM
San Yasin
Sep 29, 2015 10:52 AM
hrothgar02
Sep 28, 2015 11:08 AM
jmaxima03
Sep 27, 2015 10:22 AM
