Bad Bearings or Something Else?
Old Jul 12, 2009 | 09:23 AM
holmerica's Avatar
3rd Gear
Car: 2000 3.2 TL 109k
Symptoms: Humming/Buzzing sound from the left side of the vehicle (could be front or back) that changes tone and volume with acceleration/deceleration.
Additionally, when driving past traffic/wall/object on left side a clicking sound is heard (I'm assuming through bouncing off these objects) that can't be heard otherwise
Thoughts: I jacked the car up to check both the front left and rear left tires and didn't feel any play. The only sound heard was a light scrubbing sound as the rear left tire was rotated.
I have read that if the bearing is bad, the sound will go away or change upon turning but this does not seem to be the case.
Is it my bearings going bad or perhaps the initial sounds of a rusting exhaust (still original exhaust on there)?
Was planning on a drive of a few hundred miles today but thought twice after reading some bearing horror stories.
Old Jul 12, 2009 | 10:44 AM
juanclopez2786's Avatar
id say its the rear wheel bearings. i see them go bad alot on the acuras and hondas... very easy to replace yourself too..
Old Jul 12, 2009 | 10:53 AM
holmerica's Avatar
3rd Gear
Thanks for the input.
Do you think it would be okay to drive to a location that's about an hour away today before replacing them tomorrow?
Old Jul 12, 2009 | 06:13 PM
smartypants's Avatar
Sometimes the rotor backing plates warp and rub on the rotor causing a grinding or ticking noise. Check the backing plates by feeling for a vibration when you're spinning the wheel. If this turns out to be your problem, leaving it for now will not hurt the car. See my earlier posting for some tips on how to correct.
Let us know what you find.
smartypants
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
LoneRonin
Jan 4, 2016 01:03 AM
Brandle34
Sep 23, 2015 07:20 PM
