Back Door Won't Open!
Old Nov 1, 2012 | 09:10 PM
Tuggernaut's Avatar
Hey guys, I searched a bit and I'm pretty sure the actuator is the problem, but I just want to be sure before I order a new one.
So it started a while ago, back in the spring I guess, my back passenger side door started playing games with me. It would unlock sometimes, sometimes it wouldn't. Now it wont unlock at all. I tried with the remote, manually inside, nothing. It won't open from the inside handle or the outside. Again, I'm pretty sure its the actuator, but I want to be 100% before I get into it. So is there anything else it might be? If not, wheres the best place to get an actuator?
Old Nov 2, 2012 | 07:24 AM
3.2TLc's Avatar
Before you order the new actuator, I'd suggest pulling off the door's interior panel and check things out a bit closer. Many times, simply lubricating some components will resolve the game playing. What have ya got to lose, but to try ? Maybe save a few bucks !
Old Nov 2, 2012 | 10:58 AM
fsttyms1's Avatar
^ Odds are its the actual latch that is freezing up from corrosion. Take the door panel off and pull the latch/lock out. Make sure all parts move freely. If not soak the whole thing in penetrating oil for a while then force the parts to work and once moving keep doing it over and over and soak them more. Lube it up good before installing. (same thing happened to mine)
Old Nov 2, 2012 | 11:29 AM
Tuggernaut's Avatar
ok guys will do! Truthfully, we had the door panel off when it first started but we were more less checking if something had disconnected. But I'll check it out again. Thanks for help!
Old Nov 2, 2012 | 10:49 PM
3.2TLc's Avatar
Yeah, I guess that this is a common problem....I used to carry a small vice grip to open the blasted door lock, until fellow Ziner's led me to the fix ! It's been good since the lube job.
Feb 25, 2020 09:57 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
brandnewcolony
Sep 12, 2015 10:39 AM
Steven Vitek
ILX
Sep 10, 2015 07:29 AM
