back door on driver side locked and clock
Old Mar 28, 2009 | 05:53 AM
thekidandyou's Avatar
for some reason i think i did the child safety thingy worng and locked the back door on the drive side now for some reason it doesnt what to open any more.. And also i cant recall if there was a light for the clock mine is not work.. i need some help quick for the back door!!!!!!!!
Old Mar 28, 2009 | 01:06 PM
niju321's Avatar
dunno about the child safety thing but theres usually a tab by the door latch...
and yes, there's a light for the clock. yours has burned out.
Old Mar 28, 2009 | 05:29 PM
Wish I Had A TL's Avatar
Cool
Did you try to open the door from the outside? With the child lock on, you can only open the door from the outside, even with the doors unlocked.
Old Mar 28, 2009 | 05:57 PM
hANDYcaptd's Avatar
It's the Halladay season!
yea try opening from the outside...
and for your dash clock light..a search would have found this:
https://acurazine.com/forums/2g-tl-problems-fixes-117/dash-clock-light-out-621510/
Old Mar 28, 2009 | 06:00 PM
hANDYcaptd's Avatar
oh and i'd get the bulb from the dealer... $3-$5
saves you the hassle of wiring the radio shack bulbs
Old Apr 8, 2009 | 02:25 PM
Yes i did at first it open then i pushed down the the saftey and now it will not open at all.. from the outside or the inside.
Old Apr 12, 2009 | 10:39 PM
hey there i got a dumb thing to ask on here.. how do i up load pics ?? and i cant find the latch so i have to let some one fix it
Old Apr 13, 2009 | 12:17 AM
juanclopez2786's Avatar
7th square in on the message box. put the cursor on it and it says insert image.
Old Apr 13, 2009 | 07:28 AM
fsttyms1's Avatar
but you have to have the image hosted somewhere.
Old Apr 13, 2009 | 05:36 PM
Cool
Photobucket.com, make an account, then upload the images, copy the IMG code for that one image, and paste the whole code in the message box. cake. If you dont want to do that, E-mail me the img's, and i will upload them.
Old Apr 28, 2009 | 09:45 PM
Ok sure thing what is ur email addy
Old Apr 29, 2009 | 01:29 PM
Skeete32's Avatar
NBP
I had a similar problem, I found that the door pin some how seized up (got tight) tru pushing and pulling the pin. if you get the door open remove the panel and lube it with silicone grease or any other lube spray, dont use wd40 unless you like the smell of it in your car.
Old Apr 29, 2009 | 09:57 PM
thats the thing how do i the door to open.. since i push down on the child safety lock it has open since then from the inside of outside
Old May 1, 2009 | 09:12 AM
Skeete32's Avatar
NBP
can you rewrite that message more cleary full lettering no short form
Old May 1, 2009 | 07:45 PM
Sorry. Let me try this again. The door had opened from the inside, but not from the outside, due to the fact i had let my cousin use the car and she has kids. When i push back down on the safety lock to unlock so that i may open the door from the outside . It would not open from the outside nor the inside since that morning.
Old May 2, 2009 | 12:37 PM
spiro's Avatar
I think?? You have to remove the inside part of the lock mechanisn(the door lock handle) poke around there is an actuator of some sort that is stuck.
There is a thread somewhere on this issue, will try searching. If I find it I will post the link.
Old May 2, 2009 | 12:44 PM
spiro's Avatar
Try this:
https://acurazine.com/forums/showthr...ight=door+lock
Old May 9, 2009 | 02:48 PM
ramboe27's Avatar
I have the same problem my door is not opening from inside and out since child safty is on and outside handle is broken,help please
Old May 25, 2009 | 07:58 PM
hey there guys if any one read this i have another issue and didnt know where to post it. i have a cracked head light cover and i think water has gotten in and blown the bulb out. where can i find another cover and bulb. i would like to get a deeper blue then what already came with the car.. thanks
Old May 26, 2009 | 08:05 AM
hANDYcaptd's Avatar
You'll have to get a new headlight housing. I don't think anyone sells the front cover.
Bulbs you can get pretty much anywhere. AZ vendors or ebay is fine also.
Go to Sylvania's website to find the bulb # for your car.
As far as color, 4300k is stock so 5000k or 6000k should get you the deeper blue you want.
Old May 26, 2009 | 07:12 PM
thanks man
Old May 28, 2009 | 11:20 PM
ok have another issue.. an some one plese tell me how to get to the darn bulb so i can put a cheap one in.. hate not being able to drive at nite. . that bulb that is out is on the driver side thanks alot people
Old May 29, 2009 | 08:06 AM
hANDYcaptd's Avatar
I suggest looking through the DIY page:
https://acurazine.com/forums/2g-tl-1999-2003-98/new-official-2nd-gen-tl-diy-thread-706083/
There's a HID Removal DIY there, very easy.
Old May 29, 2009 | 09:35 AM
THANKS AGAIN Handy
Old Jul 11, 2009 | 07:06 PM
i been looking for a after maket bulbs for my car. yet i dont know which one to get.. when i look on ebay i see bulbs with two wire's hanging from the,.. do any one have a pic of the bulbs that i need to get for my car?? 2003 TL
csmeance
Jan 7, 2026 06:25 PM
Feb 25, 2020 09:57 AM
nanos
Nov 12, 2015 08:41 PM
Ny1718
Sep 11, 2015 09:21 AM
08 NBP TL
Sep 8, 2015 08:49 PM
