Axle replacement options
My driver side axle snapped the other day after falling into a monster pothole
. I have to get it replaced and I was wondering what is a preferred brand. I know OEM replacements are stupid expensive, so I wont be going that route.
I have a friend who works at advance auto and he can get me tough one axles for a bit under $70 an axle (i'll be replacing both). I also came across EMPI axles on rock auto for $50 an axle.
Is one better then the other? What would you guys go with?
. I have to get it replaced and I was wondering what is a preferred brand. I know OEM replacements are stupid expensive, so I wont be going that route. I have a friend who works at advance auto and he can get me tough one axles for a bit under $70 an axle (i'll be replacing both). I also came across EMPI axles on rock auto for $50 an axle.
You should be fine with an OEM replacement. Two of the four brands on Rockauto offer a lifetime warranty and you may get the same from Advance with out the shipping. Either way you should be fine. I would take the old CV to the store and compare the to make sure there is no big difference in the two.
Hey The-G-ride.....ya got an '03 with oem axles. While it's unfortunate that ya hit a pothole, ya really don't need to replace the other side's good axle just yet unless ya got over 200k on the car. Buy a better brand replacement axle with a warranty.
Get OEM. They have come down A TON in price and better than the replacements you get from the parts stores (which i snapped 1, and had a 2nd start causing a vibration needing replacement)
I did notice a slight vibration after the impact that wasnt there before, but I figured it was a suspension component, never crossed my mind to check the axles. Then a couple of days ago I was on a on-ramp for a highway and had to punch it hard to get on. I was doing about 40-50, when I stepped on it I felt the car downshift and then kaput, dead.
I doubt the axles could have snapped from a launch like that, so im guessing the impact had a part to play in that. Thats why I figure I should change the passenger side too, in the event that it too is damaged.
side note- can you return used axles? I'll have to call and check but I can replace the driver side one with the advance auto axle and then return it after I get the OEM ones. My tl is my dd so trying to minimize down time. The OEM axles wont get here til the end of next week.
Wow, they have come down a lot in price, I swore those things were at least 600 a piece. I was really worried about the vibration issue because i've heard that tends to happen after replacing axles with ones from a parts store. That and just the overall reliability. I just needed some clarification.
They used to be like 700. id just return it and say you were experiencing a vibration and want your money back
marcelft
Jul 10, 2018 06:17 PM
justin7779
Dec 25, 2015 10:33 PM
