anyone know how to clean EGR and IACV?
Old Mar 8, 2008 | 11:14 AM
uleiro's Avatar
im having problems at start up. car start to shake below 1000rpms for about 1 min. TCS light and CEL llights turn on. i had this problem before and i went with the coil plugs problem was solve. i didnt change all 6 coils, but i will if problem persist after cleaning EGR and IACV. if anyone can help me with a step by step procedure on how to remove and clean EGR, IACV it would do me a whole lot good and with some picture that would be perfect. thank u
Old Mar 8, 2008 | 12:13 PM
01tl4tl's Avatar
Its in the DIY section-
https://acurazine.com/forums/showthread.php?t=156252
The IAC is on the bottom of the TB assembly - 2 screws hold a cover over it
Be nice to the seal for it.
Old Mar 8, 2008 | 12:14 PM
01tl4tl's Avatar
Did you do the seafoam treatment after the coil problem- need to get everything clean, as a base line for treatment
Old Mar 8, 2008 | 02:21 PM
uleiro's Avatar
no i havent done seafoam yet but i will try that first thanx
Old Mar 8, 2008 | 02:25 PM
uleiro's Avatar
thnx 01tl im gonna use those directions
Old Mar 8, 2008 | 04:09 PM
01tl4tl's Avatar
make sure to use the new seafoam inlet place- the big vaccum nipple at the TB housing front side, you cant miss it- that will feed direct to all the cylinders and the entire manifold
Old Mar 9, 2008 | 01:10 AM
uleiro's Avatar
any picture of that?
Old Mar 14, 2008 | 05:18 AM
Luke7's Avatar
WNC Real Estate Sales99TL
what year do you have? 99? or above?
Old Mar 14, 2008 | 08:24 AM
TLS101's Avatar
I've just replaced spark plugs and timing belt. is it still ok to use seafoam in the manifild or should I just put it in the gas tank. If I just put it in the gas tank do I still need to get an oil change ater using?
Old Mar 16, 2008 | 09:48 AM
uleiro's Avatar
i have a 99 tl
Old Mar 16, 2008 | 11:41 AM
01tl4tl's Avatar
It doesnt matter if you replaced the spark plugs- seafoam will not hurt them.
You only have to change the engine oil after you put some seafoam thru the big cap marked Engine Oil
New plugs and t-belt? seafoam and really feel the differance!
fifer16
1G RL (1996-2004)
Nov 22, 2024 07:07 PM
hashbrown
Feb 18, 2022 11:20 AM
08KBP_VA
Oct 22, 2019 01:55 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
prbori
Sep 27, 2015 01:37 AM
