Another Mystery Suspension Problem
9th Gear
Hi-My '99 TL, 165k miles makes a creaking/snapping/popping sound from the front end whenever I turn or sometimes go over bumpy areas. I've had the suspension brace/bar, ball joints, etc. checked out and replaced the front struts and front motor mount. The two mechanics that looked at it said the front end is "tight". The noise has gotten a little worse over the two years since I first noticed the problem.
Any insight is appreciated... thx
I had the same problem and everyone said my front end was fine. Most likely it is the lower control arm bushings, they cost $20/each and should be replaced on both sides. It is an easy fix, more people should be doing this. I have a previous thread on this somewhere. Hope that helps!
1fatcrxnem1
22
06-01-2018 01:23 AM
MrHeeltoe
79
10-14-2015 08:47 AM
