Another Ballast Question
Old 10-06-2011, 02:41 PM
8th Gear
mccvii's Avatar
I couldn't find this in the FAQ's and How To's, if its hidden, forgive the duplicate.
I have a 2003 TL. One of my lights (drivers) wasn't coming on. I purchased 2 new lights to replace. Now, it works but not every time and the lights take a few seconds to fire up to max brightness. Sounds like the ballasts need replacing but I want to make sure I get the correct ballast.
I don't want to buy a whole kit as I just purchased 2 new lights . I'm looking on HIDExtra.com. I know I need the 35W AC ballast but I don't know if that's everything. I called but the person I spoke to kept coming back and forth to the call relaying information from someone else so I didn't get a good feeling.
Most of the FAQ's talk about the entire kit but I want to know is if I can disconnect the stock ballast and reconnect the aftermarket ones inline using the existing wiring.
Old 10-10-2011, 08:47 AM
8th Gear
mccvii's Avatar
Guess this was too difficult. As Acura has explained, you cannot add an aftermarket ballast. I guess that must be the case here.
Thanks anyway.
Old 10-10-2011, 09:28 AM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
You can add an aftermarket ballast, it wont be plug and play with the oem harness but you can add them.
Old 10-10-2011, 10:53 AM
99Ackrite
Diva 4 Life's Avatar
@fsttyms1
If you cut the harness off the oem ballast to use the plug & play ability and use connectors to put the aftermarket ballast harness together that would be the easiest way correct?
Old 10-10-2011, 11:44 AM
fsttyms1's Avatar
Yes, you could do that.
Old 10-10-2011, 12:09 PM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
at hidextra you would order the 2 ballast and 2 `connector wires`
1 `relay kit` is a good idea too for the extra 16 bucks
getting the kit- if package deal is a better price- gives you 2 spare bulbs.
just in case whatever brand you have dies someday
I believe in having a backup plan --and parts - when reasonable--
bulbs are hard to find local in an emergency, keeping spares seems reasonable
navtool.com
3G MDX (2014-2020)
32
01-20-2016 11:43 AM
navtool.com
31
11-16-2015 08:30 PM
Juandiablo
09-27-2015 10:32 AM
navtool.com
09-25-2015 05:15 PM
Quick Reply: Another Ballast Question
