All kinds of problems
Old Dec 18, 2005 | 12:27 PM
honda_inspire99's Avatar
Skeet Skeet Skeet
Today i notice on my 99 TL that i could move the shifter without the keys in it or stepping on the brakes which i dont think should happen and the D4 light is blinking, the green key light is blinking and the now the car wont even turn over or start... please can someone give some info that might help me thanks
Old Dec 18, 2005 | 01:03 PM
Pure Adrenaline's Avatar
Dragging knees in
There was a recall for the ignition lock. Acura found out that in some TLs, you could take the key out without the shifter being in park, which could result in the vehicle rolling away.
Everything is most likely related to that problem (shifter out of park without the key in the ignition probably triggered the immobilizer system), so take it to the dealership and have the recall performed.
Old Dec 18, 2005 | 03:29 PM
Skeet Skeet Skeet
k thanks man, so the dealer is the only place to fix the imobilizer if thats thats the problem? any more ideas would be aprreciated thanks and where is the imobilizer unit located?
Old Dec 18, 2005 | 03:53 PM
Dragging knees in
I don't know where the immobilizer unit is, and even if I told you, there's nothing you can do with it.
I mean, it could be from a number of other reasons, but my money would be on the ignition lock recall.
If you want to force start the car, then check the driver side fusebox. Locate the fuel pump fuse, and it is most likely fried. If it is, then replace with a new one, put the shifter back into Park, and the car should start.
If not, call the dealership for a tow. Good luck.
Old Dec 18, 2005 | 06:13 PM
fsttyms1's Avatar
There was a recall for it. bring it in and have it replaced
Old Dec 18, 2005 | 07:09 PM
Skeet Skeet Skeet
but would that stop it from starting? whenever i put the key the on position the green key light start to flash is that normal?
Old Dec 18, 2005 | 07:17 PM
Dragging knees in
The green key sign is for the vehicle immobilizer.
I don't know exactly for sure if it's caused by the ignition lock problem, but my best guess would be that it's related. With the shifter out of park, with no key in the ignition, the immobilizer must be thinking that the ignition system has been bypassed/broken in order to put the car in gear.
Have you checked the fuel pump fuse yet like I said? If it's shorted, then replace with a new one, and that *should* start the car again.
Old Dec 18, 2005 | 07:31 PM
Skeet Skeet Skeet
yea the fuse is good i tested it with a fuse tester and i also removedthe starter and everthing looks good on it...I forgot tomenton that the ecu got wet so could that be the problem? thanks everyone for their comments cuz i know little about the TL but its just another honda with time i'll know everthing i need to know ps. so much easier workin on ma gsr.
Old Dec 18, 2005 | 07:34 PM
Dragging knees in
It could be.
pstomps
Feb 20, 2017 03:29 AM
Sep 17, 2015 09:01 PM
DwDrummer
5G TLX Problems & Fixes
Sep 14, 2015 08:20 PM
brandnewcolony
Sep 12, 2015 10:39 AM
