Emergency Break
Old Dec 18, 2005 | 06:59 PM
NYanks78's Avatar
Emergency Break
Hello, Im having a problem with my emergency Break, I changed the breaks and changed the rotors and now it seems like the emergency break is on when Im driving on the rear passenger side, does anyone have a setting or know something that can help me, Thank You
Old Dec 18, 2005 | 07:06 PM
Pure Adrenaline's Avatar
Dragging knees in
What do you mean by "it seems like" the emergency brake is on? Do you feel it dragging or something?
When you drive your car with the emergency brake engaged, you will notice an immense amount of heat coming from the brakes because the brake shoes will rub against the inside of the hat constantly. Also, you will notice a drag, like when you let off the throttle, the car will slow down faster than normal by itself.
Old Dec 18, 2005 | 07:07 PM
NYanks78's Avatar
Yeah, The car doesnt move when it in gear usless I press the gas and if I go about 10 mph or more I feel dragging
Old Dec 18, 2005 | 07:15 PM
NYanks78's Avatar
Anybody
have
any
suggestions
Old Dec 18, 2005 | 07:19 PM
Dragging knees in
Try pumping the emergency brake pedal several times to release it. If that doesn't do it, then the emergency brake must be seized.
You will have to take off the rotor to get to the mechanism inside and adjust it.
Old Dec 18, 2005 | 07:22 PM
NYanks78's Avatar
Does anyone have any diagrams for adjust ments for the emergency break
Old Dec 18, 2005 | 11:28 PM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
Seized caliper? Take the wheel and brakes back off and reinstall them and see what happens.
Old Dec 19, 2005 | 12:14 AM
NYanks78's Avatar
Bleeding the Breaks
I just took off the tires and everything seems better but now theirs a new problem, my pedel when I brake goes all the way to the floor, Im assuming I need to bleed the brakes, the brake line in one of the calipers was loose, and fulid came out, does anyone have any suggestions or diagrams on bleeding the brakes, Please HELP!!! Thank You!
Old Dec 19, 2005 | 01:08 AM
03CoupeV6's Avatar
I'm not sure what has happened, but next time I'd let a professional do the brakes.
Old Dec 19, 2005 | 08:03 AM
Bareback's Avatar
TL = Tranny Lubrication
This is what I have found:
If the brake master cylinder is empty, the brake pedal will go to the floor. If this is the case, you will have to bleed the brakes in addition to adding fluid: Time to see your mechanic, who will flush and refill the braking system.
Find the brake master cylinder. Towards the back of the engine compartment - driver’s side - Add brake fluid only if the fluid is below the "Low" line. If the fluid is below the "Low" line your brakes should be inspected for wear or leaks. Use the correct brake fluid - Fill up the brake reservoir with an approved brake fluid.
Properly support your car on Jack Stands and remove your wheels.
Starting with the right rear, remove the rubber nib covering the bleeder screw and undo the bleeder screw approx. 2 turns. The brake fluid will slowly run out, so it would be best to use a container to capture it.
Allow approx. One half bottle of brake fluid to drain, then re-tighten the bleeder screw. Spray off the caliper or rear of the drum with brake cleaner.
Do the same for the other wheels in this order; left rear, right front, left front.
Be careful not to allow the reservoir to run out of fluid. Do Not touch the brake pedal at anytime during this process.
Don't drive a car that has run out of brake fluid until bleeding the brakes.
Old Dec 19, 2005 | 10:50 AM
NYanks78's Avatar
THANK YOU EVERYONE, I bleed the breaks and everything seems great for now, Lets keep our fingers crossed, Thank everyone for their help
Old Dec 19, 2005 | 03:16 PM
fsttyms1's Avatar
acording to the honda service manual thats not the correct bleed procedure, the order is LF RF RR LR.
lanechanger
Oct 13, 2015 10:56 AM
steve
Sep 30, 2015 09:23 PM
kixo
Sep 25, 2015 03:07 PM
tndirtdauber
Sep 23, 2015 03:00 PM
