air stopped working
Old Jun 9, 2009 | 10:20 PM
keydarnell's Avatar
air stopped working
My a/c and my heat won't work. When I turn on my air nothing happens. The a/c pipe stays warm when I turn the a/c on. The heat does not work. The blower does not come through the vent. The fuses are good. Every now and again it will come on. Can you help?
Old Jun 10, 2009 | 01:19 AM
Gfaze's Avatar
S E L L
The TLs had a problem with the blower motor connector overheating, which melts the ends and toasts the terminals and part of the wiring. You'll have to get in there and cut out the bad part so you can splice in a new one. I think you can get a replacement at the dealer or you can make your own by buying some wire terminals at a hardware or automotive store. That should fix the problem.
Old Jun 10, 2009 | 09:37 PM
keydarnell's Avatar
Thanx Gfaze...
Old Jun 11, 2009 | 01:15 AM
Gfaze's Avatar
S E L L
Originally Posted by keydarnell
Thanx Gfaze...
No problem,
Old Jun 14, 2009 | 05:26 PM
5daddy13's Avatar
PNYXPRS
Harness is $12 at the dealer. Mine had melted the connector on the blower as well and cost me another $115 for the blower.
While you are in there, pull the glove box and check you air filter.
Old Jul 6, 2009 | 03:29 PM
randomwalk101's Avatar
I just replaced the a/c air filter but i don't see any blower/connector you're talking about. Will you give me some more specific instruction as to how to get the blower motor and connector out? thanks.
Old Jul 6, 2009 | 09:30 PM
totaledTL's Avatar
See if this helps: car.justanswer.com/uploads/acuramstr/2008-02-25_171912_blower.pdf
01CLOwner
Oct 9, 2015 01:07 PM
SilverJ
1/2G MDX (2001-2013)
Sep 21, 2015 02:40 PM
acurajj
Sep 19, 2015 03:47 PM
theinsvnity
Sep 10, 2015 10:22 PM
dlknight
Sep 3, 2015 07:54 PM
