air intake computer ajust? more or less power?
Old Nov 21, 2008 | 03:03 PM
gold2003tl (90)'s Avatar
2003 TL-p
after i first put the air intake in i got bad mileage but a lot of power. after the computer adjusted my mileage went up a lot....but did i lose power?
it almost fells like after the computer adjusted to the new air intake i lost power? but i could be wrong.
what happens when the computer adjusts? does it try to restore factory horse power? but like i said, i am not sure if the car has less power but after driving for a few weeks with the intake on it just does not seem like it was a peppy as it felt when i first put it in.
thanks
AEM short ram ( and it does suck up cold air from the cavity the resonator used to be in - i closed it off so it does with a custom box) pics are coming soon.
Old Nov 24, 2008 | 04:58 PM
2003 TL-p
i just put the box in when i posted , after doing so i felt even more power. i guess the computer will adjust again.
but what is the computer doing - letting less fuel in or more. changing the mix of fuel and air? i can tell when it adjusted because the pitch of the engine changed slightly and became a little softer. i am going to up load the pictures shortly.
basicly used a small piece of sheet metal and aluminum tape to make the block off. it matched the tube (color wise) and doesnt look ricer.
Old Nov 24, 2008 | 05:21 PM
rob-2's Avatar
Whats probably happening is with the modifications you get a slight gain in power, but it quickly becomes what you expect every time.
Old Nov 24, 2008 | 05:33 PM
2003 TL-p
thanks, but does anyone have this happening to them? i know like almost everyone hear has an intake - they must be seeing the same thing happening? no? its not that i have gotten my power level restored to 225 hp, its just the car does not seem as peppy as it did when i first put the intake on. but at the same time it might have more torque and power its just the engine sounds pitch has changed a little making it seem like it has less power.
honestly i dont know if the change the computer made did anything (besides mileage) , my next step i guess is the dyno.
Old Nov 24, 2008 | 05:35 PM
2003 TL-p
hear are the pics of the intake warm air block off.
[IMG]
http://s437.photobucket.com/albums/qq98/pyromonster99/acurazine/?action=view&current=DSCF0218.jpg[/IMG]
http://s437.photobucket.com/albums/q...t=DSCF0219.jpg
http://s437.photobucket.com/albums/q...t=DSCF0223.jpg
Old Nov 24, 2008 | 05:36 PM
2003 TL-p
ahh some of them did not work hold on
Old Nov 24, 2008 | 05:38 PM
2003 TL-p
http://s437.photobucket.com/albums/q...t=DSCF0171.jpg
http://s437.photobucket.com/albums/q...t=DSCF0170.jpg
http://s437.photobucket.com/albums/q...t=DSCF0218.jpg
Old Nov 24, 2008 | 05:39 PM
2003 TL-p
sorry about the bad links in the other post - my bad
Old Nov 24, 2008 | 06:17 PM
Edward'TLS's Avatar
6G TLX-S
The only way to tell is a trip to the dyno. Some intake/exhaust upgrades gain hp at the low/mid rpm bands, but lose hp at the upper rpm band. Others gain hp at upper rpm band, but loses more at the low/mid rpm bands.
Old Nov 24, 2008 | 06:26 PM
2003 TL-p
iv felt a lot more low end torque as well as more power in the v-tec band. over all i know i have more power - 0-60 is down to 7.2 sec from the stock timed 8 sec. on a good day iv have gotten a flat 7 sec maybe even under 7 sec now with the block off i made.
mainly i want to know is if the cars computer adjusts for less power after a mob is put in? or even if the computer may adjust for more power
thanks again very much
Old Nov 24, 2008 | 06:27 PM
2003 TL-p
mod correction spelling *above
Old Nov 25, 2008 | 01:20 PM
rob-2's Avatar
I believe the computer is ALWAYS readjusting. With an increase in air into the motor it will add more fuel to keep the proper air/fuel mixture. With more air and fuel you should be producing more power.
I stick by my statement that you are getting used to the additional power and so it stops feeling new. Get to a dyno to know for sure.
Old Nov 25, 2008 | 01:44 PM
2003 TL-p
yea, because in the summer time when it is hot out the air is less dense, and winter it is cold out so it has to adjust. since i made my heat shield it seems to have the most power yet. it is faster and i think it is staying that fast.
but you are right about mostly likely getting used to having more power.
thanks again
Old Nov 25, 2008 | 03:09 PM
rob-2's Avatar
thanks again
You can always reset your ECU by removing the clock back up fuse for 1-2 minutes. Forces the computer to relearn from factory settings.
BOOSTED6IX-S
Feb 22, 2016 01:53 PM
drone619
Jan 26, 2016 07:09 PM
mikeytown2
Sep 21, 2015 12:41 PM
Sep 17, 2015 08:57 PM
Sep 14, 2015 10:09 PM
