ahhh err 1....err 2.....
Old Sep 30, 2008 | 02:41 PM
Bonestock TL-S's Avatar
hey just recently disconnected the battery then when hooked up the battery i knew i had to have a cd player code....have the code, put it in, and err 1....tried again then err 2
any suggestions??????
greatly appreciated
Old Sep 30, 2008 | 02:54 PM
Bob_F's Avatar
Sometimes pulling the antenna connector out of the back of the radio will allow the code to be accepted. Search the forum for details.
Old Sep 30, 2008 | 02:58 PM
thescoundrel's Avatar
+1 yeah, just disconnect the antenna connector and re-enter code. Once code is accepted, re-attach antenna connector.
Old Sep 30, 2008 | 05:06 PM
thanks guys
Old Sep 30, 2008 | 09:43 PM
totaledTL's Avatar
Really- never heard of that- doesn't make sense, how could that do it
Old Oct 4, 2008 | 03:14 PM
i tried the antenna connector thing and no luck.....its the black cord on the bottom driver side right?????
Old Oct 4, 2008 | 04:22 PM
9932's Avatar
2G wanting 3G
yes. i think your supossed to pull that and with it unplugged put your code in.
Old Oct 5, 2008 | 12:34 AM
tried the antenna connector didnt work....tried the main fuse under the hood didnt work....gonna try to disconnect the main fuse and antenna tomorrow hope it works.....if it doesnt any more suggestions???
Old Oct 5, 2008 | 06:17 PM
tried taking out antenna connector and disconnected the main fuse for 10 secs put in code and err 8!!!!!!!!!!!!!!! started at err1 and now tried 8 times.....dunno wat the deal is...plz help
Old Oct 5, 2008 | 06:34 PM
Bob_F's Avatar
There are a ton of threads on radio "security code entry" problems. The antenna connector and fuse tricks don't always work. Search the forum for some other things to try.
Good luck!
Bob
Old Oct 6, 2008 | 05:04 PM
9932's Avatar
2G wanting 3G
the only thing that it could be is your putting in the wrong code. take your dash apart and get the s/n off the radio and call the dealer. unless its a 6disk, then you can just hold 1&6 and turn on the radio and it will tell you code. then call dealer.
Old Oct 6, 2008 | 05:24 PM
6MTUA5's Avatar
No He Can't
I think you must have the wrong code. Get the S/N off the radio and call your local dealership to get the code.
Old Oct 8, 2008 | 11:28 PM
Thanks got the s/n and will call dealer tomorrow hope they arent...well u know how dealerships are...o and this might be obvious but dont leave change between the heated seat buttons cuz I GOT JACKED like 5 bucks
i got jack by the techs at the dealership
Old Oct 9, 2008 | 09:13 AM
Bob_F's Avatar
Check out post #22 in the following thread:
https://acurazine.com/forums/2g-tl-problems-fixes-117/2003-3-2-tl-radio-codes-error-message-642967/
There's a link for retrieving radio codes online. I've never tried it but it might be worth a shot.
You can also try calling another local Acura dealer. Some dealers are more helpful than others.
Tim Giron
Mar 18, 2016 09:50 PM
