AHH NEED HELP! overheating!
Maybe you have some trapped air in the system. Try bleeding it per the procedure & see if it cures it. Never known a water pump to screech. Been my exp. that they will start to leak a small amount, then gradually worsen maybe with bearing failure type of noise.
Anybody else? Air in the system, fan temp sensor, thermostat?
I attempted burping the system this evening. Jacked up the front end, took off the cap, heater on hot high, turned on the car . . . .massaged the top rubber hose . . . seemed to work, but then the problem happened again tonight.
I have the mechanics' manual(s) so I'll look around in that to see if I can get more detailed instructions than I've found on here. I hope it's something as simple as an air pocket.
What the the symptoms of a bad water pump????
