AC/heat stopped blowing
I posted this before, sorry guys could not find the post. This has happened in the past, my ac/heater stopped blowing, the responses I received back from you guys pointed to a plug on the passenger side under the glove compartment, I wiggled it a little and it came back on but I did notice it was somewhat burnt. Now it appears that plug is bad completely but I think its melted into the slot and now I cannot get it out. Can someone please give me advice as to what to do in order to get this piece out. Hope someone know what I'm referring to. Thanks.
go to the dealer and ask for the UPDATE KIT for the blower motor connection $20
Comes with longer wires so it wont happen again
May need a new resistor for fan it its been shorted out/failed
once you pull the cabin filter and blower/motor mount you can see exactly whats needed
It sounds worse than it is to do
see diy/garage section for `cabin air filter`- the glove box comes out and a few pieces- nothing but screws and pop offs- simple
you said it was already burnt at the connector- a well known problem and a fix availabe from acura
burnt electrical only gets worse and turns into a major dash fire
If you have nerves of steel and great insurance--
Always Working In
Three weeks ago I had the same situation happen. No heat or air. Compressor wouldn't kick in. Did the diagnostic for the climate control unit. Sure enough blower motor problem. Plugs was fried like yours. Mines burnt so bad it melted inside the motor connector. Ordered the new harness from acuralynn on ebay and a motor since the terminal was burnt from another ebayer and I'm all good. Easy job like everybody says. I have pics ill post em this afternoon
thats definetly a toasted part!!
imagine if that got worse and flames erupted inside the dash!!
MrHeeltoe
20
02-23-2023 01:54 PM
spoiler900
10-10-2015 06:48 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
