abs tcs! and vsa
Old Feb 19, 2015 | 05:00 PM
type-s02's Avatar
3rd Gear
abs tcs! and vsa
How exactly is the paper clip method done. I found the method for a tsx but is it different for the tl-s?
Old Feb 19, 2015 | 07:20 PM
01tl4tl's Avatar
welcome to the forum
the paper clip is to reset a false srs code if you removed seat wires with battery connected
for the multi codes you got that turned on all the lights:
go to a parts store and ask for a code reading- its free (except Ca)
codes are CLUES not cures or diagnosis inthemself, so report whatever they find back here
Example multi cyl misfire codes = 1 bad coil
what did you do right before all the lights,,a burnout in the rain or sudden stop with abs operating?
whats the current car miles?
after you get the codes and do a repair, reset the ECU by removing the CLOCK fuse on passenger end of dash or kick panel for 1 minute, then reinsert
its the secret backup power to ecu and forces a full reset/clears codes and relearn
Old Feb 20, 2015 | 09:46 AM
type-s02's Avatar
3rd Gear
hmm
the paper clip is to reset a false srs code if you removed seat wires with battery connected. Side airbag of lights up now and again.
Example multi cyl misfire codes = 1 bad coil closest place it's dealer that can scan it but they want 50$ to scan it I hoped I wouldn't have to go there.
Snow on the ground it lost traction for a minute. But the lights came on as usual for a sec. Lost traction again then the lights all came on and stayed. Runs fine still have abs and no funny sounds or shuddering.
whats the current car miles? 145,700
Old Feb 20, 2015 | 09:57 AM
01tl4tl's Avatar
ok those conditions can trigger false codes
Go ahead and reset the ecu by pulling clock fuse as instructed above
See if lights come back on after normal driving for a few weeks
don't need dealer on this!
you seriously don't have a name brand parts store closer than 50 miles! must be nice~
if using quote system= please put your answer on a separate line so its easy to find and read
Old Feb 20, 2015 | 10:01 AM
01tl4tl's Avatar
Side Airbag light- see owner manual for full operation of system
free download at Acura Owners Site | Exclusive Knowledge, Service, & Benefits (usa cars)
Basically passenger seat has sensors looking for weight of passenger, and shift in weight indicating passenger is leaned forward or seat is leaned way back =
in which case the side airbag is disabled so as not to injure passenger in airbag deployment up the side of their seat
can break a neck easily
If carrying anything at all in pass seat, or buddy is doing movement when light comes on = that's your answer
mada51589
Jan 9, 2025 04:40 PM
Jamus22
Jun 11, 2023 10:08 AM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
polish_pat
Sep 30, 2015 12:22 PM
