ABS and TCS Light ON
Old May 25, 2006 | 12:53 PM
saad12's Avatar
Hello,
I just noticed that the ABS and TCS light just came on.
The car has only 55000 miles on it.
I was wondering what could be this issue - the car runs perfectly fine without any issues.
Thanks,
Old May 25, 2006 | 12:54 PM
phipark's Avatar
Not Asian
Something is probably wrong with your ABS unit. I would reset it and see if it comes back on. If it comes back on, take it to the dealership. Keep in mind, while that light is on, I believe your ABS is disengaged.
Old May 25, 2006 | 01:58 PM
optomos's Avatar
I=X - optomos
Also take it to a local auto parts store and have them read the codes for you and let us know what they are.
Old May 25, 2006 | 09:41 PM
TexasHonda's Avatar
An OBD2 code reader can't read ABS codes. On earlier models (to 98) you short the 2-wire Service Check Connector under the glove box and ABS light flashes the codes. I believe Acura discontinued this w/ later models, but if the blue SCS connector is under the glove box, give it a try. A special ABS diagnostics test unit may be necessary to obtain codes.
You will probably need a shop manual to get the code meanings.
Does the pump come on when you start and attempt to charge until the ABS light comes on? If yes, check fluid level in the ABS. It may be leaking fluid. This can be repaired sometimes.
good luck
Old May 29, 2006 | 05:58 PM
On my 2002 tl-s the vsa and abs light were on....it turned out to be the abs modulator. Hope this helps
Old Jun 10, 2006 | 11:47 PM
nit78's Avatar
Did you by any chance just change the insturment cluster. Sometimes the wrong clust will give you both errors.
Old Jun 22, 2006 | 11:05 AM
victorvu's Avatar
i just changed the cluster and both lights are on any way to turn it off? also VSA button doesnt even work.
Old Jun 22, 2006 | 11:35 AM
cjde2006's Avatar
you have to get them reset if you changed the cluster
Old Jun 22, 2006 | 11:53 AM
victorvu's Avatar
anyone know how to do this or only take it to the dealer?
Old May 30, 2007 | 11:16 AM
Itch71's Avatar
Originally Posted by saad12
Hello,
Thanks,
I have the same problem on 99TL. ABS and TCS light always on. They lit up together about 3 months ago. I no longer have TC or ABS. Since both these functions no longer work, can I assume that the problem lies in the modulator....or can it still just be 1 sensor?
Itch
Old May 30, 2007 | 01:36 PM
fsttyms1's Avatar
it could be a sensor since teh abs and tcs are the exact same system. Bring it in to get diagnosed
mada51589
Jan 9, 2025 04:40 PM
Yikes
May 3, 2021 04:29 PM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
Bahamanurse1
Sep 10, 2015 10:05 PM
