Old Dec 4, 2006 | 04:39 PM
onebadtls's Avatar
onebadtls
Question ?
have an 03 tl-s and was wondering why when i have the heat on i think i hear the compressor kicking on? maybe im just nuts but im curious...thanx for the input
Old Dec 4, 2006 | 05:35 PM
CJITTY's Avatar
Ackniculous One
If you are using "Auto", it is using the compressor to regulate the climate control system, so yes, you are right.
I only use Auto in the summer when it's hot. Every little bit of gas savings helps, especially since we require premium fuel. Most of the time, I use the fan and I adjust the temp control manually to avoid the A/C compressor coming on. It's not as accurate, but gets the job done. Also, when you hit the defroster button, I believe the AC kicks on as well to remove moisture and that gets rid of fogging on the windows.
