99 TL problem
Old Apr 23, 2006 | 07:41 PM
MrPreludeSH's Avatar
99 TL problem
I have a 99TL, with 135K on the clock, so far no major problems, 2 motor mounts and 1 tranny mount.
Recently, I had a problem where the car started and then stalled, then started and everything was fine. A few days later same thing again.
I took it into a shop and he checked the throttle body and said he cleaned it a little, he checked the EGR and said it looked OK but cleaned it out a little.
Today when I started the car was surging at idle. 500 to a little less than 2000 rom, anyone have any suggestions??
Keith
keith@eppys.com
Old Apr 23, 2006 | 08:11 PM
NSXNEXT's Avatar
The surging is the idle air control valve. Do a search. It's a valve that's attached to the bottom of the throttle body. The shop, by cleaning the TB, must have clogged the IACV.
Old Apr 23, 2006 | 08:37 PM
fsttyms1's Avatar
Old Apr 23, 2006 | 08:50 PM
NSXNEXT's Avatar
Oh and the stalling could be the ignition switch. There is a recall by Acura to fix it. Contact your local Acura dealer to find out if your car is under the recall.
Old Apr 23, 2006 | 09:33 PM
so if it's clogged to i just change it or can it be cleaned?
Keith
Old Apr 23, 2006 | 09:34 PM
ignition switch recall was done years ago, thanks for the input
Old Apr 24, 2006 | 10:35 AM
optomos's Avatar
I=X - optomos
Keith
IAC, you would just replace.
Old Apr 24, 2006 | 12:05 PM
NSXNEXT's Avatar
Try to clean it first. Worst thing that happens is you can't. The IACV is a $100+ part.
Old Apr 24, 2006 | 11:11 PM
honda_inspire99's Avatar
Skeet Skeet Skeet
Just changed mine today, i ordered it from DCH Honda in CA and i got it for $95 eith over night shipping not my car idles so much smoother
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
