99 tl engine coolant temperature sensor
Old Feb 29, 2016 | 11:51 PM
JustJustin69's Avatar
My 99 tl is hard to start when it's warm. Drive it for 10-15 mins and shut it off then go to restart a few mins later and it idles rough and usually stalls. If I can get it started and Rev the engine a bit for a min and then get it into drive and drive it 10 feet it's fine. I've Googled it and sounds like it is heat soak and the engine coolant temp sensor needs to be replaced??? But I'm not sure where that is on my engine. None of the videos seem to show my specific model. I'm not great at this DIY car stuff and unfortunately I can't afford to pay a mechanic (single dad), so any help would be greatly appreciated. Also going to attempt to change my brakes for the first time this weekend. And the tranny is shifting really hard. Especially when its cold and downshifting to a higher rpm. Any links or help would be great. Thanks everyone.
Old Mar 1, 2016 | 02:21 AM
01acls's Avatar
FPR
Disconnect the battery before working on the FPR. You will need the radio code.
^How the FPR should be after it's installed.
See the link below.
https://acurazine.com/forums/problem...ura-tl-941112/
Old Mar 1, 2016 | 02:38 AM
01acls's Avatar
Engine temperature sensor... see Post #5 in the link below.
https://acurazine.com/forums/problem...-issue-935658/
Old Mar 1, 2016 | 03:02 AM
01acls's Avatar
See this link about your trans.
https://acurazine.com/forums/second-...-929498/page2/
Flipster23
Norcal
262
May 4, 2023 02:47 PM
mlody
Dec 4, 2019 02:11 PM
rsteagall
Oct 11, 2018 06:43 PM
thisaznboi88
Mar 15, 2016 04:27 PM
ExcelerateRep
Feb 4, 2016 10:57 AM
