99 with 01 swap
Old Jun 6, 2008 | 12:18 PM
blacktlr's Avatar
99 with 01 swap
i have a problem i have 99 tl but i put in a 01 swap with all the harness from the 01 cluter shift box and ecu ,, already got the key programmed for the ecu and it already turned on fine the last problem the a have is that the D5 is blinking and it wont go in to triptronic and when i put it on d5 it feels like its on its final drive but when i put it on D2 it moves with power but i have to shift it manually ,,, does this car uses a seprate ecu for the tranny???? by the way before dropping the swap in my car i tried it in the 01 it drove like new on 55k on the whole swap
Old Jun 6, 2008 | 02:15 PM
Rajca's Avatar
wham bam thank you ma'am
is everything connected electrically and mechanically? make sure your not hitting anything while trying to get into teh tip tronic mode
Old Jun 6, 2008 | 10:56 PM
blacktlr's Avatar
everything is
Old Jun 7, 2008 | 09:09 AM
fsttyms1's Avatar
And im assuming you put in the 5 speed trans as well?? Have the codes read. there has to be a code. It will help narrow down whats wrong.
TypeS860
Jan 10, 2026 11:11 AM
Jul 16, 2017 07:33 AM
samson_420
Oct 8, 2015 01:47 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
hpfiend
Sep 27, 2015 06:59 AM
