3.2 TL gas leak
Old Apr 26, 2011 | 12:00 PM
Mbob's Avatar
3.2 TL gas leak
Hi guy's
Me TL 99 begin to smell gaz, and the gaz leak if the car is park the front lower...
Is it very hard to replace the gaz tank , or do you thionk that the leak can coming from other source like gasket or other ??
What is the best stuff cab i use to repair a gaz leak ?
Any input will be appreciated so thank's for your help !!!
Old Apr 26, 2011 | 01:12 PM
fsttyms1's Avatar
Can you be a little more specific? Where is the gas leak coming from? The gas tank or somewhere else?
Can you take a pic?
Old Apr 26, 2011 | 01:15 PM
Rockstar21's Avatar
The Dumb One
gaz
Old Apr 26, 2011 | 02:07 PM
Mbob's Avatar
I see that the gaz come from the upper of the tank's but i can't confirm where exactly come from, that's why i ask if it can be a gasket...
The car have 12 years old, it's mayby normal that some of you had this problem ??
I've check and if i want to remve the Tank i will have to remove the exhaut line too !!!!
If i remove the rear seat can i have some access to the tank and check where that gas can leak ???
Thank's very much !!!
Old Apr 26, 2011 | 03:53 PM
fsttyms1's Avatar
No you cant remove the back seat to see. That will just show you the trunk. You have to pinpoint where its leaking from for us to be able to help you.
Old Oct 10, 2016 | 11:07 PM
Gabru678's Avatar
Bump as I think I am having this issue also.
But I have been looking it up and it seems that this happens past a certain point on the gas where there is a seam?
Does anyone know where this seam could be? And how I may be able to repair it externally?
Old Oct 11, 2016 | 08:15 AM
SykVSyx's Avatar
Derek
Seems to be a common problem, I haven't looked for myself, but my MIL is having the same leak issue, somewhere near the tank, from what I can tell.
Will take a look this evening to update where the leak appears to be coming from.
Car was going to the shop tomorrow for the repair.
It's a '00.
Mike734
Dec 10, 2021 01:25 PM
Avenger411
Oct 11, 2015 03:53 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
San Yasin
Sep 29, 2015 10:52 AM
