2004 ody trans in 2000 tl
I bought a dirt cheap 2004 ody trans and torque converter from a repo van and now have both transmissions out and have noticed that the heater assemblies are totally different and will not interchange.What do i do now?Use the ody assembly or return the trans and wait till i can find and afford an av6?
what does our diy says about years that works?
Its one of the top threads on the main list
I got the trans in and the heater situation figured out but it wont move at all in any gear like its not even trying.I used all solenoids and switches and sensors from the original tl trans cause it worked just was slipping in 3rd gear.I put the torque converter from the ody.Kinda wondering if the tq isnt bad.
the trans you put in is most likely bad. Need to rebuild one of your transmissions, then reinstall.
even if the tc is bad the car will still drive, just not very well.
S power
10-28-2017 06:52 AM
Syms
08-30-2016 08:07 AM
