2003 TL Fuel Stalling issue?
Old Apr 28, 2025 | 09:04 AM
Matt_C's Avatar
Hello Everyone, I have a problem with a 2003 Acura TL 3.2l. I have replaced the fuel pump, fuel filter, map sensor, fuel pressure regulator. When you try to pull out and give it gas it acts like it wants to flood out. I am getting lean and trim on bank 1 codes. It has also started when it gets hot the RPM's drop and it starts shaking and stalls out. It takes a while to get it started back but then the rpms drop again and stalls out. When the engine is cold it seems to run fine. Any ideas?
Thank You,
Matt
Old May 1, 2025 | 09:52 PM
whitetiger5's Avatar
doesn't sound good. what fuel pump/filter did you replace it with? It's not uncommon that some brands will fail on arrival.
dylanrcharb
Jul 9, 2024 06:04 PM
Jax_666
Sep 17, 2022 10:19 PM
Lennon Giesbrecht
1G RDX Problems & Fixes
Feb 21, 2019 09:25 PM
molok0
Nov 19, 2018 12:47 PM
gangstaTL03
2G CL Problems & Fixes
Oct 10, 2009 04:34 PM
