2002 type-s electrical problem... no interior lights
Old May 11, 2014 | 09:40 AM
AdumJens's Avatar
I was in the process of changing all my interior lighting from stock to LED.
They worked for a bit, but as i was finishing up all of them stopped working at once including the trunk inside light.
a check engine light also came on which didnt make sense to me, my fogs stopped working, and i cant use the homelink.
Now the check engine light is gone, and my fogs work, but some dash lights (AC) dont work, along with all my interior lighting not working.
please help?
Old May 11, 2014 | 11:09 AM
ErickUa5's Avatar
Mr.Helpful Diagram
Sounds like a couple of fuses blew check all your work and replace the burned fuses with the same amperage rating. Theres fuses under the hood and on the driver side panel that relate to this issue but check them all.
Old May 11, 2014 | 12:11 PM
Skirmich's Avatar
You blew out a fuse.. This little guy has been a problem solver for me for Years:
Pretty cheap:
http://www.ebay.com/itm/Littelfuse-L...-/271369040354
You can also found it on Autozone dunno for how much but its common! Check that it has those 3 posts because you will need them! Those are for ATO (Standard Size Fuses) and MINI (TL small Fuses).
Old May 11, 2014 | 07:56 PM
AdumJens's Avatar
I checked the fuses and they were all good...
Old May 11, 2014 | 08:09 PM
ErickUa5's Avatar
Mr.Helpful Diagram
Are you certain that all fuses are good under the hood, drivers side panel and passenger side ? Id say remove all the LEDs may have a shorted one.
I can take a guess, Maybe the Multiplex control unit is in fail safe mode.
Try removing the negative battery cable for about 5 minutes then put it back, see if helps. Now beware it will reset everything so have your radio code or else you wont be able to use it.
Old May 12, 2014 | 12:49 AM
AdumJens's Avatar
I'll try the battery thing tomorrow and I'll post on if it works or not
Old May 12, 2014 | 01:20 AM
Skirmich's Avatar
You have a blown fuse somewhere for sure.
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
PortlandRL
Sep 14, 2015 12:01 PM
brandnewcolony
Sep 12, 2015 10:39 AM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
