2002 tl type s used engine
Old Dec 20, 2009 | 08:38 AM
bama boy's Avatar
i had a used engine put in my car its got 44,000 miles on it runs great other than sometimes it idels real low and when i give it gas it wont go until it catches up does it mostly when its cold but sometimes when it warm it like jerks when i give it gas
Old Dec 20, 2009 | 09:40 AM
sbuswell's Avatar
I need 2 more gears
have you checked your air filter? I'd check that and change if need be, then seafoam it, change plugs and then run some fuel system cleaner. If that doesn't work clean your EGR valve. Are you getting a CEL?
Old Dec 20, 2009 | 08:01 PM
Rajca's Avatar
wham bam thank you ma'am
iacv, clean or replace.
Old Dec 20, 2009 | 10:27 PM
sbuswell's Avatar
I need 2 more gears
Maybe it's the idle control valve, but not necessarily. If the idle is just low it could be poor air intake. If the idle is bouncing up and down at idle then it's almost 100% the IAC valve.
Old Dec 21, 2009 | 06:18 AM
Luke7's Avatar
WNC Real Estate Sales99TL
Clean the intake idle contol valve on the throttle body.
Old Dec 21, 2009 | 12:00 PM
fsttyms1's Avatar
If its idling low and with your symptoms it may be a IACV (clean like the others stated) it may also be the TPS (throttle position sensor) Clean your throttle body out and clean the IACV and see if that helps. Run some seafoam or fuel injector cleaner thru your fuel system as well
sockr1
Oct 1, 2015 01:31 AM
Billu99tl
Sep 13, 2015 11:30 AM
kuzdu
Sep 10, 2015 08:42 PM
ellisd03tls
Sep 8, 2015 04:17 PM
