2002 tl type s used engine
i had a used engine put in my car its got 44,000 miles on it runs great other than sometimes it idels real low and when i give it gas it wont go until it catches up does it mostly when its cold but sometimes when it warm it like jerks when i give it gas
have you checked your air filter? I'd check that and change if need be, then seafoam it, change plugs and then run some fuel system cleaner. If that doesn't work clean your EGR valve. Are you getting a CEL?
Maybe it's the idle control valve, but not necessarily. If the idle is just low it could be poor air intake. If the idle is bouncing up and down at idle then it's almost 100% the IAC valve.
If its idling low and with your symptoms it may be a IACV (clean like the others stated) it may also be the TPS (throttle position sensor) Clean your throttle body out and clean the IACV and see if that helps. Run some seafoam or fuel injector cleaner thru your fuel system as well
sockr1
Oct 1, 2015 01:31 AM
Billu99tl
Sep 13, 2015 11:30 AM
Mugen TSX
Eastern Canada
Sep 1, 2015 11:11 PM
