2002 tl transmission
Old Aug 20, 2012 | 06:55 AM
APROBLEM4's Avatar
Transmission on its way out ........I got a friend that has found a 03 transmission for a TL with 80 thousand miles and a 02 with 113 thousand miles......my TL is a type s these Tl's are regular......does that matter...what should I look for on these used transmission......the used transmissions both thousand bucks each....install 400.....any input would be helpful....
Old Aug 20, 2012 | 10:40 AM
01tl4tl's Avatar
see threads on using an accord or oddy trans both of which are better than a tl trans
Old Aug 20, 2012 | 02:19 PM
Stephen00TL's Avatar
Chapter Leader (Southeast Region)
Don't use the 99-03 Acura tl transmission, especially with that high of mileage. You will be running into the same problems with those. Try a lower mileage Honda odyssey or Honda accord v6 06-07 tranny. You can get one of those for around the same price with less miles. All you have to do is swap the range switches, tl filter and assemy, and maybe a few other things but it's easy and alot of people have done it. I myself will be swapping in a 07 accord tranny soon.
Old Jan 8, 2013 | 05:34 AM
32tl00tuneacura's Avatar
So what did you end up doing with it?
Old Jan 8, 2013 | 06:49 AM
fsttyms1's Avatar
If you are looking for a trans alternative, get the accord trans. It is better than the CL/TL trans and works with the change of a few sensors.
TypeS860
Jan 10, 2026 11:11 AM
knight rider
Mar 4, 2016 08:59 AM
joflewbyu2
Oct 8, 2015 11:16 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
hashbrown
Sep 29, 2015 12:13 PM
