2001 Overheating
Old Apr 22, 2007 | 06:36 PM
CallawayGolf's Avatar
2001 Overheating
Hey guys,
I have a 2001 TL with 143,000 on it and it has been a great car for me. Just in the past day or two it has been heating up to the point where the dash indicator is 3/4 the way up to the red line. It had usually never barely made it over halfway. Any ideas??? Thanks.
Old Apr 22, 2007 | 09:19 PM
01tl4tl's Avatar
Did you replace the water pump at 105 with the timing belt?
Or you could have a bad fan sensor not kicking the radiator fan on
How does it look inside the radiator cap?
Old Apr 23, 2007 | 11:36 AM
Black-Balled's Avatar
WILL PLAY POOL FOR CASH
As long as you are not into the red, it is OK. That said, be sure your cooling system is in proper order and you should be good.
Old Apr 23, 2007 | 11:40 AM
NSXNEXT's Avatar
If the needle is not 1 click below halfway, have it checked out. As mentioned above, it could be a couple of things:
1) radiator fan switch (idle the car for about 15 and make sure the fan kicks on)
2) time for a fluid change
3) radiator cap going bad
4) thermostat going bad
Old Apr 23, 2007 | 11:46 AM
fsttyms1's Avatar
Pham Alvan
Mar 16, 2016 09:17 AM
NorthWestAnimal
Sep 28, 2015 06:20 PM
CWOVette
1/2G MDX (2001-2013)
Sep 27, 2015 02:29 AM
3.5RLv-tec?
Sep 7, 2015 11:00 PM
NSolace
Sep 3, 2015 08:02 PM
