2000 TL Ticking from Coil Pack
Old Feb 6, 2020 | 12:11 PM
Marsalis Simms's Avatar
UA7_Unknown
Was driving my car whilst working today and noticed an unusual ticking sound coming from the bay. Leaned in closer and heard it coming from just one coil pack, which was also leaking oil. It’s strange because I just replaced my valve cover gaskets and tube seals and all less than 10k miles ago. I’ve noticed no change in performance or idle, no lights on the dash or anything else out of the ordinary. My assumption would be it’s a bad coil and I guess the seal on that particular plug needs to be replaced as well? Haven’t encountered an issue like this previously so would like further insight. Thanks in advance
Old Feb 6, 2020 | 12:13 PM
oil leaking from the coil pack?
sounds like maybe the person who replaced it might not have seated the seals properly
Old Feb 6, 2020 | 12:52 PM
UA7_Unknown
would that be causing the other symptoms I’m having?
Old Feb 6, 2020 | 01:09 PM
whitetiger5's Avatar
what other symptoms? ticking? rough idle? perhaps the boot isn't seated all the way and the ticking is electricity arcing?
Old Feb 6, 2020 | 01:46 PM
UA7_Unknown
Other than the ticking and oil there are no other symptoms. Idle is normal and acceleration does not seem to have been affected either.
Old Feb 6, 2020 | 03:52 PM
Iggy's Avatar
Were the spark plugs pulled at all? Double check that plug is tight.
Old Feb 7, 2020 | 09:33 AM
UA7_Unknown
yes, all spark plugs were replaced at the time as well. But yeah I’ll try that and make sure
TL fiend
Oct 2, 2019 11:43 AM
manavycop
1G RL (1996-2004)
Sep 21, 2019 12:14 PM
uneedkhoality
Feb 23, 2016 02:35 PM
Thunder82
Dec 23, 2014 03:59 PM
TLBaller
1G TL (1996-1998)
Nov 30, 2005 10:07 PM
