2000 TL Tail Light Assembly Replacement
I am new to the brand itself and am upgrading to the 02-03 tail lights. Is the removal and installation relatively self explanatory or would I need any special tools? Any advice or instruction would be greatly appreciated 👍🏻
very easy. Here's the manual which tells you everything you ever wanted to know: Click here
The most difficult part is that you have to bend back the trunk liner. Unscrew the cargo net posts and pull out the plastic tabs holding down the plastic piece on the lip of the trunk. Then you should be able to get to the lights no problem.
bforbrian
Jun 5, 2008 10:51 PM
