2000 tl piston slap
Old Dec 2, 2009 | 09:38 AM
gregyb123's Avatar
8th Gear
2000 tl piston slap
Im experiencing a piston slap during cold start. Is it normal for this car ???
Old Dec 2, 2009 | 09:57 AM
Ron A's Avatar
Administrator
Welcome to the forums.
I moved this to the 2nd Generatrion TL Forum since you indicate you have a 2000 TL.
Old Dec 2, 2009 | 11:38 AM
gregyb123's Avatar
8th Gear
Old Dec 3, 2009 | 06:02 AM
gregyb123's Avatar
8th Gear
Does anyone here have any suggestions ???
Old Dec 3, 2009 | 08:34 AM
fsttyms1's Avatar
Piston slap is not normal on these cars. Are you sure its that? I have only seen 1, maybe 2 possible cases of it in all my years here.
Old Dec 3, 2009 | 09:10 AM
gregyb123's Avatar
8th Gear
Well I have done most of the test that one can possibly come up with. But it becomes very obvious when I pulled the coil off the plug while car was cold the noise have faded instantly. But what bothers me the most that the noise is only there when there is a load. I mean when I engage drive or reverse. It is happening on 2 cylinders. The car just hit a 100000 mile mark and I have always been using premium gas and synthetic oil. Also the valves were adjusted by dealer less than 6 months ago. If you or anyone have any common suggestions please share them with me.
Old Dec 4, 2009 | 09:36 AM
fsttyms1's Avatar
If it is infact that there isnt any thing you can do other than a tear down or replace the motor. Since you have had some work done on it your only recourse is to live with it or pick up a used low mileage motor and stick it in (they can be found for 5-800 bucks now) These motors are very strong and that isnt typical.
Old Dec 4, 2009 | 10:06 AM
gregyb123's Avatar
8th Gear
Thank you for your answers. I kind of figured that this is what will have to take place but needed a second opinion.
Old Dec 7, 2009 | 11:56 AM
TLer trash's Avatar
Unless the noise really bothers you, I'd do nothing. Although rare on honda v6 engines, it's not uncommon on high mileage honda 4 cylinders. I've seen many go well over 100k miles more after the noise started. On the ones I've owned, I let them warm up a few minutes or drove easy for the first few miles. The only one I ever tore down still had cross-hatching on the cylinders, and the aftermarket pistons measured SMALLER than the ones I took out. I put it back together with the old parts and lived with the slap.
Old Dec 8, 2009 | 04:32 AM
gregyb123's Avatar
8th Gear
I love the car a lots but I hate the sound. Im going to pull the motor and look inside for something abnormal. I have checked the oil pressure which looks great and the compresion checked 175 on all cylinders. I just want the car to be quiet in the mornings again.
The diesel kocking just makes the car sound like a junk.
SidhuSaaB
May 30, 2020 12:40 AM
acuratl26
Apr 23, 2020 07:30 PM
Jul 16, 2017 07:33 AM
ceb
ILX
Sep 27, 2015 10:56 AM
