2000 -2003 engine interchangable with 99?
Old Oct 20, 2012 | 09:10 AM
okckat's Avatar
looking to pick up new engine today at JY, found cheap 2001
but ebay site said fit 2000-2003 , so does 99 model diff from the rest? need to some insight on what the the different if any.
please help
Old Oct 20, 2012 | 11:05 AM
assclown's Avatar
2000 acura tl FPR
Yes. The 02-03 models came with either a j32a1 (what you have) or a j32a2 (type-S). You will want to get a j32a1.
There are differences between the 99's j32a1 and the 2000-2003 a1. Intake manifold is different, I believe the 99 has two sensors on the water valve next to the EGR valve, but it's possible to do. I'd make sure you'd get a service manual to understand the differences.
I know NSX-Next did an intake manifold swap on his 99, he might be able to give you some insight.
Old Oct 20, 2012 | 11:46 AM
fsttyms1's Avatar
You can get any 99-03 J32A1 and make it work just fine.
Old Oct 21, 2012 | 03:56 AM
okckat's Avatar
thanks. got the 99 engine Saturday, now working on removing process. hopefully install would go a lot quicker.
Old Oct 21, 2012 | 07:15 AM
deeplies's Avatar
What will do you with the engine? replace?
Old Oct 21, 2012 | 08:04 AM
3.2TLc's Avatar
Just to clarify: you originally stated that you had a '99 TL needing a new engine. Did you end up getting that '01 engine for a replacement ? If so, use Assclown's advice for ease of effort !
Old Oct 21, 2012 | 02:22 PM
johnnybegood_5's Avatar
Hate to be a noob but how can you tell the difference in the 2 engines?
I have a 2000 3.2L TL, that i want to swap the engine and transmisson into a 99 with the aero body kit. Both cars say 3.2 TL on the back. The 2000 has a flat silver plate on top of the intake, the 99 has a shape as the intake itself.
Any help is appreciated, any engine swap links out there?
Old Oct 22, 2012 | 08:26 AM
3.2TLc's Avatar
welcome.....Johnnybegoode !
Hey for the best detailed comparison of differences between the '99 and '00 & up, get an early service manual for the '99/'00. You can download this if you look around a bit.
Old Oct 22, 2012 | 11:07 AM
fsttyms1's Avatar
As for the engines, there isnt much difference other than the intake flows better and different fuel rails to fit under the 99 intake. The 2000+ base TL engine will bolt up to the 4 speed trans.
Old Oct 26, 2012 | 06:54 PM
okckat's Avatar
To save time I got 99 engine to replace.
got new one in the other now just need all the harness in place .
will report back if it start ok
Old Oct 26, 2012 | 07:03 PM
3.2TLc's Avatar
Good luck on the swap, the '99 will make things go easier for you !
Heyzuez20
Oct 14, 2015 07:18 AM
gehrlichman
Sep 22, 2015 10:08 AM
krenaue
Sep 15, 2015 07:54 PM
MikeYutkin
Sep 10, 2015 10:13 PM
Mike Bertram
Sep 10, 2015 09:27 AM
