2000 -2003 engine interchangable with 99?
looking to pick up new engine today at JY, found cheap 2001
but ebay site said fit 2000-2003 , so does 99 model diff from the rest? need to some insight on what the the different if any.
please help
please help
2000 acura tl FPR
Yes. The 02-03 models came with either a j32a1 (what you have) or a j32a2 (type-S). You will want to get a j32a1.
There are differences between the 99's j32a1 and the 2000-2003 a1. Intake manifold is different, I believe the 99 has two sensors on the water valve next to the EGR valve, but it's possible to do. I'd make sure you'd get a service manual to understand the differences.
I know NSX-Next did an intake manifold swap on his 99, he might be able to give you some insight.
You can get any 99-03 J32A1 and make it work just fine.
Just to clarify: you originally stated that you had a '99 TL needing a new engine. Did you end up getting that '01 engine for a replacement ? If so, use Assclown's advice for ease of effort !
Hate to be a noob but how can you tell the difference in the 2 engines?
I have a 2000 3.2L TL, that i want to swap the engine and transmisson into a 99 with the aero body kit. Both cars say 3.2 TL on the back. The 2000 has a flat silver plate on top of the intake, the 99 has a shape as the intake itself.
Any help is appreciated, any engine swap links out there?
welcome.....Johnnybegoode !
Hey for the best detailed comparison of differences between the '99 and '00 & up, get an early service manual for the '99/'00. You can download this if you look around a bit.
Good luck on the swap, the '99 will make things go easier for you !
gehrlichman
09-22-2015 10:08 AM
krenaue
09-15-2015 07:54 PM
Mike Bertram
09-10-2015 09:27 AM
