2 Lights on the dash.
Old Jul 10, 2013 | 11:20 PM
Jmpx55x's Avatar
Well i recently bought a 2000 acura TL, and no lights were on at time of purchase, and now the D5 light is blinking, i've read this has to do with the tranny, the people i bought it from said they had the tranny replaced about a year ago, i checked the fluid, the level seemed fine, and its not shifting hard, or slipping so i have no idea what is wrong. Also the SRS light came on too, any ideas?
Old Jul 11, 2013 | 12:14 AM
Skirmich's Avatar
Go to Autozone and get Codes pulled... Then come back here for further help.
Old Jul 11, 2013 | 12:24 AM
Jmpx55x's Avatar
Can they pull the codes? I thought they could only pull Check engine light codes? if they can ill post back tomorrow
Old Jul 11, 2013 | 12:26 AM
Skirmich's Avatar
SRS Codes Nope but if D5 is blinking then those codes are Stored at OBDII.
Old Jul 11, 2013 | 12:31 AM
Jmpx55x's Avatar
Acura/honda dealers can pull the SRS right? Can regular garages too or just acura? and roughly how much does it cost to just get a code pulled?
Old Jul 11, 2013 | 12:48 AM
Skirmich's Avatar
The SRS Code reader its a Honda Mechanic tool only.. There are Generic Readers out there if your lucky a Suspension or Body Shop could pull those up but I would not bet on it.
SRS Pull Codes are Expensive last time I tried to Pull those on my local Stealership they wanted 90 bucks just to read the codes! They would not charge it tought if I fixed the problem with them.
Old Jul 11, 2013 | 07:00 AM
3.2TLc's Avatar
Check the "DIY" sticky....there's a reset procedure for the SRS. Try it and see if it clears the light. If not, then ya may have something else going on that needs checked with the system. When the SRS light is on, your airbags are inoperative.
Old Jul 12, 2013 | 06:17 PM
comet24's Avatar
I just did the SRS light reset thing posted online. Very easy to do. My light is off for now so we will see if it stays off.
I'm sure there are other thread but I just used the info here to do it.
https://acurazine.com/forums/2g-cl-problems-fixes-70/how-reset-srs-light-742517/
Old Jul 23, 2013 | 02:03 AM
Jmpx55x's Avatar
Just an update, i reset my SRS light, and it came back on, then i reset it again and now it seems to be staying off, weird D5 light stop blinking now too, have no idea what that was about, i didn't even get a chance to see what was causing it.
Old Jul 23, 2013 | 07:38 AM
3.2TLc's Avatar
"D5" blinking......
Yeah, check for a stored code !!!
uzzmaan
Aug 4, 2025 08:29 AM
mada51589
Jan 9, 2025 04:40 PM
Dec 7, 2020 05:39 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
