2 ignition coil n spark plug replacement
Old Mar 23, 2011 | 10:02 AM
Marion88's Avatar
9th Gear
the mechanic by my house is charging me 430 to replace 2 ignition coils and a spark plug ... is this fair or is he trying to rip me off?
Old Mar 23, 2011 | 11:26 AM
01tl4tl's Avatar
coils are about 50 bucks each at any parts store
it takes about 20 minutes to replace 2 coils,,and 3 minutes to replace a spark plug at the dead coil,,but he should be doing 2 plugs if 2 coils--note those times are generous!!
YES are being ripped off!!!!!!!!!!!!!!!!!!!!
the neighbor kid can do the same work if you are not able,,its simple
remember: you MUST reset the ecu computer for the car after new coil-
remove the CLOCK fuse for 1 minute--its on the end of dash on passenger side- open door- see plastic fuse box cover,,its a red fuse iirc but clearly marked diagram on cover
Old Mar 23, 2011 | 11:27 AM
01tl4tl's Avatar
if you give us your city, there is probably a fellow member that will come help you out
Old Mar 23, 2011 | 01:04 PM
Marion88's Avatar
9th Gear
thNks alot ... how much is a reasonable price for that job?
Old Mar 23, 2011 | 05:26 PM
01tl4tl's Avatar
parts: 2 coils $100, 2 spark plugs under 20 = 120...135 with max tax rate
labor: maybe 30 minutes at a very casual pace,,, and never seen a TL before!!
NOT the place for your car to be- in my opinion
Sounds like they want parts or labor for 6 coils, or 6 plugs- but only doing 1 or 2!
May have been an ~accident~ in not changing the shop `quotes computer` to 1,,from All
cycdaniel
Dec 17, 2019 10:58 AM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
Soul_Deamon
Sep 7, 2015 04:25 PM
NSolace
Sep 3, 2015 08:14 PM
quake97
Aug 30, 2015 07:57 PM
