159K fixes??
Old Mar 31, 2015 | 07:01 PM
JMitch4031's Avatar
159K fixes??
Hi all I have a 01 TL just turned 159K this week any suggestions on what I should have checked out, repaired or replaced for the future?
-J-
Old Mar 31, 2015 | 08:17 PM
musiclevelz5's Avatar
Do you have the Acura manual in the glovebox? It should tell you what you need to do at what mileage/years. I would go by that. Unless you do not have anything needing repair right now I would not worry too much.
One thing I would do is start saving up for an AV6 swap/6mt, whatever you prefer, for when your trans takes a dump, which it will do, only time will tell when it happens.
Obviously this is only if you plan on keeping the car for a long time. As the TL trans is the only known major issue and everything else on the car will perform great with routine maintenance.
Old Mar 31, 2015 | 09:33 PM
Skirmich's Avatar
Ball Joints, Sway Bar Links, Radius Rod Bushing, Basically check every single rubber thing in the car which should be dry or hardened by now.
Old Apr 1, 2015 | 10:46 AM
01tl4tl's Avatar
flush brake fluid, flush ps fluid, Change trans fluid and filter, USE HONDA DW-1 ATF
ck coolant- only get 5 years max after the initial 7 years/105kmiles on oe coolant
additives break down and do bad things to aluminum home!!
Old Apr 1, 2015 | 10:48 AM
01tl4tl's Avatar
new brake lines- oe are rubber, 100-125 dollars gets you a full set of SS lines which give improved braking and don't wear out like rubber
Mike734
Dec 10, 2021 01:25 PM
SidhuSaaB
May 30, 2020 12:40 AM
thegipper
Sep 28, 2015 01:01 PM
h22lude
Sep 27, 2015 06:22 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
