03 TLS Timing Belt Replacement
Old Mar 9, 2011 | 06:02 PM
TyBran's Avatar
I am buying parts for my timing belt job and wondering if I need this part
14520-P8E-A01ADJUSTER, AUTOMATIC
14520-P8E-A01 - ADJUSTER, AUTOMATIC
Old Mar 9, 2011 | 06:23 PM
TyBran's Avatar
Should I replace this 14550-PGE-A01 IDLER, TIMING BELT (KOYO SEIKO) ?
Old Mar 9, 2011 | 11:38 PM
01tl4tl's Avatar
timing belt tensioner and the idler pulley are very important
they may be ok today, but no way going to last another 100kmiles and maybe a lot less~
it either fails its the same as breaking the belt = massive internal engine damage
dont squib on these parts--much needed!!!
Old Mar 10, 2011 | 04:23 PM
Flipster23's Avatar
get them yes!!
Old Mar 10, 2011 | 08:11 PM
TyBran's Avatar
Thanks guys, I will replace the said parts.
Old Mar 11, 2011 | 11:28 AM
01tl4tl's Avatar
never have wiser words been typed!!!!
make sure to ck the rad hoses condition- new thermostat never a bad plan
saves you from draining the coolant again in a year when those are bad~
if in the budget- valve adjust never hurt,,a few will be off and perfect makes the car run better, more efficient in this $4+++ headed for $5 a gallon days- I want max mileage,,, when not hot footing around~
if shop doing valve adjust is not in current budget- DIY EGR port system cleaning by removing intake manifold
I mention it with valve adjust since the IM comes off to access the valve covers--for some combined labor savings
merc009
Sep 14, 2015 06:43 PM
iCrap
Sep 11, 2015 06:21 PM
Phambam12
Sep 5, 2015 04:10 PM
asahrts
Sep 4, 2015 05:55 PM
