03 tl ruff idle problem help!!!!!
Old Apr 17, 2013 | 09:41 AM
R2D's Avatar
R2D
I have a 03 TL and i am having a idle problem. I have uesd the "SEARCH" button...
My problem is when i start the car its idling low like it wants to die. when i drive the car it feels fine but as i come to a stop it feels like it wants to die or should i say idling really low.... I have a new battery so its not that. Spark plungs are good.
So what could this be? IAC? EGR? only?
Old Apr 17, 2013 | 10:08 AM
R2D's Avatar
R2D
and i dont not have any check engine light or any other light on....
Old Apr 17, 2013 | 01:43 PM
closetprisoner's Avatar
2000 Acura TL
Without the code, my first guess would be IACV
Old Apr 17, 2013 | 02:59 PM
R2D's Avatar
R2D
okay. well im going to clean the IACV and the EGR just in case its the Egr...
Old Apr 17, 2013 | 03:03 PM
victus1's Avatar
Yep, a sticking iacv or egr can cause this symptom. Get yourself a can of carb cleaner. And if you remove both, get the iacv gasket and egr valve gasket too....they will need replacing. Open the valve on the bottom of the egr with a flat screwdriver and spray tons of cleaner in there. After clean up, lubricate the arm.
4drviper
Apr 23, 2025 07:13 PM
SidhuSaaB
May 30, 2020 12:40 AM
mdlex389
4G TL Problems & Fixes
Sep 28, 2015 06:29 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
TL14
Sep 24, 2015 04:37 PM
