02' TL-S P0505 "idle air control system" error
My 2002 TL-type S is having some idle issues. It's idling and running rough and the RPM's are intermittently shooting up and down when idling. I scanned it and got a PO505 idle air control system error. It's also stalled on my at random when I'm driving at less than 15 mph or sitting at a stop sign. No idea how to handle this, any thoughts? Thanks a million!!!!
Take the Idle Air Control valve off the bottom of the Throttle Body and clean it. If that doesnt work you may need a new one
bringin lead
bringin lead
i installed the p2r spacer for the tl-p and the new tb bolts they provided were too short to accommodate the p2r spacer and stock spacer. long story short, it was jimmy-rigged based on bad advice i received. now all is well as i now have the correct bolts, spacer, and stock spacer in the correct order.
mrkingstonvi
02-22-2016 01:53 PM
09-17-2015 09:01 PM
