01 TL New coil packs for sure, BUT WHAT ELSE?
So two days ago im doing an oil change on my 2001 TL, and i needed another quart so i go back to schucks, I decided to do a spark plug change as well. while im at my house doin the spark plugs it starts to rain so i have my friend go turn the car on enough so that i can put it in neutral and we can push it into my garage, well his dumbass decided to try and turn the car fully on, which ended up shootin the coil packs out because i had already takin the spark plugs out and i set the coilpacks back in their slots because it was raining. so now Ive got a diagnostics test and these are the codes that came up, I went to www.canobd2.com and figured what they mean.
P1519 - Idle Air Control Valve Circuit Failure.
P1399 - Multiple/random misfire detected.
PO300 - Pgm-Fi system and a/t system program mismatch
PO420 - Catalyst system efficiency below threshold(bank 1)
PO131 - HO2S-11 (bank 1 sensor 1) circuit low input
P1259 - V-Tec stsyem B1 failure
PO304 - Cylinder 4 misfire
PO305 - Cylinder 5 misfire
PO306 - Cylinder 6 misfire
Whats your guys take on it, Im hopin some of these codes are from the misfiring from the bad coilpacks so maybe some of these codes will go when i fix that but I dont know. Im not even sure what most of this stuff means.
reset the ecu AFTER all the work is done, Then see what codes come up. until then i wouldnt worry about it.
What?
Questions
How do you reset the ECU? and what does it do?
So i took it to a shop and i guess two spark plugs were blown and one coil pack is done for, so after i fix all that up ill get my ecu reseted and get another test after that.
If you reset the ECU the ECU thinks its corrected because there is no code in it. If there is still a problem the ECU will detect it and throw a code. If you dont correct the problem resetting the ecu is pointless. Pull the clock backup fuse for 1 min.
Sarlacc
Console & Computer Gaming
09-30-2015 02:15 PM
Hines57
09-24-2015 01:58 PM
