Spacer install progress
Old Jan 7, 2008 | 04:25 PM
jayunsplanet's Avatar
I'm waiting for my mom to get here so I can take her car to the store for some more carb cleaner. Ugg!! So in the meantime, here are some progress pics! This is a tad scary...
Errmm uhh. Yea...
Before...
Last hour...
Someone took a runny dump in my intake manny
Old Jan 7, 2008 | 04:54 PM
AMGala's Avatar
Lamborghini Aventador FTW
Take EXTRA care with the studs and nuts and bolts to ensure that they don't fall into the block. If they fall in and slide down, you are F'ed.
Old Jan 7, 2008 | 04:58 PM
ryebreadisme's Avatar
Low and Slow
Cool pictures Jason. Good for any guys looking into the spacers. They definitely help a little. TL-power.
Old Jan 7, 2008 | 04:59 PM
Old Jan 7, 2008 | 05:04 PM
02type-s's Avatar
-Arsenic-
Keep us posted
Old Jan 7, 2008 | 05:10 PM
JCharged's Avatar
Awesome just did mine a few months ago. Hope all goes well with the install.
Old Jan 7, 2008 | 06:38 PM
Well, I'm "done". Started the car... Idles @ 2k rpm. I assume this just means the throttle cable needs to be adjusted? I guess I have to play with it?
Old Jan 7, 2008 | 07:09 PM
jjashaa's Avatar
Avant Garde Wheels
idle at 2k?! whoa... maybe u forgot to put some hose back on... don't ask me which one.... hahaha
Old Jan 7, 2008 | 07:48 PM
^Nah, it's the throttle cable. It needs to be adjusted just right. I got it down to 700rpm @ first idle...
When I brake, the last few feet, it revs up like 150rpm, just enough to give a little jump forward.
When I parked it after a long drive and adjusting the cable a few times during the drive, it idled back at 1200rpm.
Not quite sure what's up other than the throttle is open just a weeee bit. I'm probably just gonna take it to my local shop and have them adjust it in 5 minutes rather than me tinker with it.
But WOW. I can def feel the extra kick. It's quite prevelant from 15-60mph acceleration. Those low RPM's def got a boost.
Old Jan 7, 2008 | 08:30 PM
Here are a BUNCH of pictures throughout the install...
http://pictures.jayunsplanet.com/thu....php?album=174
I would have loved seeing pictures like this before I did mine... just so I could know what to expect.
Old Jan 7, 2008 | 09:26 PM
AznWay's Avatar
Very nice D.I.Y.
Old Jan 7, 2008 | 11:04 PM
SSMTL01's Avatar
I did the same thing yesterday minus the spacer install and am having the same issue with the 2000 rpm idle. It's only in park though. In d or ss, it idles at 1k? From what i've read it could also be the idle air control valve, which is part of the throttle body. Did you remove your throttle cables?
Nice pics too.. i agree that it is scary as hell looking at your engine like that.. and then starting it up hoping that you didnt miss any coolant lines..
Old Jan 7, 2008 | 11:07 PM
SSMTL01's Avatar
Also- I can see there was oil in yours too.. Is that from the EGR?
Old Jan 7, 2008 | 11:15 PM
WDPTLS's Avatar
How often do you guys clean out your throttle body and egr? I did mine a few monthes ago and was wondering if I should do it again tomorrow or not. I'm just wondering what time frame you guys wait to do it.
Old Jan 8, 2008 | 12:00 AM
01tl4tl's Avatar
The throttle cable should have a small amount of play, the car should idle normal at 700 with the cable loose. Was the IAC cleaned while the TB was off- its under a cover on the bottom of TB
I think there is a connector that can get confused with another and that will make it run bad
see this thread for good tips
https://acurazine.com/forums/showthread.php?t=156252
Old Jan 8, 2008 | 12:05 AM
01tl4tl's Avatar
WD- if you removed the intake manifold and cleaned the ports for the EGR you should be good another 70-100k miles
Use of Seafoam cuts down on carbon buildup in the intake system,
there is nothing you can do that prevents egr buildup
Throttle body- If you sprayed into it while on the car and followed the directions about- with the throttle plate closed or open, repeat a 2nd time to get everything really well.
While not required- I reset the ECU by disconnecting the battery- clean the cables and terminals and put back together
You can also pull the clock backup fuse and that is power to the ECU
Old Jan 8, 2008 | 09:52 AM
Ok.
I started the car this morning. Idled @ 700rpm in P, N, and D. Drove fine few a few blocks. Got some breakfast, left the car running. Drove for about 5 minutes and got on the highway. At which point the check engine light and the TCS light came on. Why?
I haven't since restarted the car to see if they come back.
Old Jan 8, 2008 | 10:05 AM
SSMTL01's Avatar
Haha you cant just ask why- it could be so many things.. go to autozone and get the code scanned
Old Jan 8, 2008 | 11:09 AM
PiZauL's Avatar
W00t
Nice write up Jason Sucks that when you do a DIY, it never corporates 100% (at least in my experiences haha.. if you remember my ksport installation lol).
Old Jan 8, 2008 | 11:52 AM
fsttyms1's Avatar
You shouldnt have had to adjust the cable. If you are experiencing a idle issue you need to recheck the bolts, hoses and gaskets. It sounds as though you have a vacuum leak
Old Jan 8, 2008 | 12:28 PM
01tl4tl's Avatar
the TB spacerblock changes the distance so the cables need to be readjusted slightly.
Sort of like the engine cover needs a little bit of dremel to fit over the TB now, so I left the cover off for improved cooling.
I would lube the cables while its all apart too.
Old Jan 8, 2008 | 12:30 PM
01tl4tl's Avatar
If you have a vac leak- what was the condition of the base gasket that gets reused- and the spacer had its proper gaskets? and nothing is overtight??
Old Jan 8, 2008 | 12:58 PM
jjashaa's Avatar
Avant Garde Wheels
really? mine doesn't idle like that, got mine installed myself and everything is good...
^^^ See below. No more idle issues (knock on wood)
Only issue is CEL and TCS lit up.
Originally Posted by jayunsplanet
Ok.
Old Jan 8, 2008 | 01:03 PM
fsttyms1's Avatar
oops, forgot about the TB spacer
Old Jan 8, 2008 | 08:31 PM
@cUr@-TL's Avatar
'99 Acura 3.2TL
your problem sounds like a vacuum leak as it's been mentionned.
james357
Feb 13, 2016 02:37 PM
ryanfett
Oct 29, 2015 06:01 AM
MonkeyTrucker
Sep 21, 2015 06:15 PM
TxRzrBk
Sep 17, 2015 01:07 PM
yvr_tsx
Sep 15, 2015 01:14 PM
