Pic Request - Gps Antenna
Old May 22, 2006 | 12:05 PM
JMAL's Avatar
Hey for all the aftermarket navi people, where did you mount the navi antenna?
J
Old May 30, 2006 | 11:13 AM
Shane Scully's Avatar
I see you have a Pioneer AVIC Z1... I was thinking getting one myself for my 02 TL
and i wanted to see how it would look. If u have any pics i'd appreciate it.
Did you run into any issues with the installation?
Old May 30, 2006 | 11:21 AM
JMAL's Avatar
you can see what i have done so far
https://acurazine.com/forums/showthread.php?t=137321
yeah its a pain, enless you want to pay 250 for the install kit. but im stubborn and bored. i havent gotten it into the car yet, but that is not what i was worried about. making the mounting kit was the hard part. follow that thread and i update it with progress. i also have pics of all the steps incase i feel like making a diy for it.
Old Jun 8, 2006 | 07:32 AM
Bxscig's Avatar
Figure out a location for the GPS antenna yet? I've read they say keep it about 12" away from another antenna but on the TL the antenna is on the rear window. I would of thought that would be the best place to mount it.
Old Jun 8, 2006 | 07:57 AM
JMAL's Avatar
i havent decided yet, im thinking if it reaches, the rear deck. if not im going to go wth front dash. i dont want to put it outside because i dont want to advertise that i have after market navi.
Old Jun 8, 2006 | 09:05 AM
ITL's Avatar
ITL
I do my own work.
front dash, right next to the tweeter on the passenger side.
Old Jun 15, 2006 | 09:28 AM
Bxscig's Avatar
if you remove the cover for the stock sub... that whole peice including the 3rd brake light, you can put the antenna there.
I just checked and if u put it right between the 3rd brake light and the window. it is trapped inside and it would not crimp the wire or put any stress on it.
Do you know where I am talking about? If anything run the wire down the center to save some slack.
Old Jun 15, 2006 | 11:51 AM
JMAL's Avatar
awesome idea. im def going to do that. how does that cover come off. i have never looked, plus i wanna take out the stock sub since i have new ones i can use that as like a port.
Old Jun 15, 2006 | 12:31 PM
Bxscig's Avatar
I just did it myself actually.
If you remove the rear seats it is easier but if you dont it is just slightly harder.
If the rear seats are removed just pull up, the clips will snap out.
If not...... If you remove open that cover holds a clip in the center, you can pull up and snap that out as well. Then use a 12mm bolt to remove that clip. Then from the left and right side, wedge your fingers in or a flat head screw driver on each side and wedge it up.
I didnt have my camera today, otherwise I would of taken pictures for u. I can show u the final product.
Old Jun 15, 2006 | 12:33 PM
Bxscig's Avatar
The sub is helddown with 4 8mm bolts i believe.
Old Jun 15, 2006 | 12:34 PM
Bxscig's Avatar
Open cover #20, pull out so it looks like #16, remove bolt and wedge.
Old Jun 15, 2006 | 04:03 PM
JMAL's Avatar
your the man. thats all i have to say.
oh yeah and thanks! ill post pics of the install on saturday.
Old Jun 15, 2006 | 10:37 PM
Bxscig's Avatar
Old Jun 15, 2006 | 10:40 PM
Bxscig's Avatar
Hope this helps you on Saturday. Pretty much step by step and the 4 screws that hold the stock sub down
Old Jun 16, 2006 | 05:29 AM
JMAL's Avatar
tight, thanks again man. that was so very helpful, i didnt even think of that. i might put foam under the whole housing to prevent rattles of the new subs.
Old Jun 19, 2006 | 07:23 AM
JMAL's Avatar
thanks man, i pulled the stock sub, which is inverted design, which is random, its not like there isnt room. i mounted the antenna to that brace that runs under the 3rd brake light but is kinda under the sub grille. thanks for the help, i finished the avic z1, its great. check it out
Old Jun 19, 2006 | 07:51 AM
Bxscig's Avatar
Does it receive the signal well there though? I thought sub grille would cover it and stop it from working. It would be nicer to mount it there so it is totally not visible.
Old Jun 19, 2006 | 07:56 AM
JMAL's Avatar
nope works perfect. the rule with satellite antennas are they they dont have to be visible or outside. they just cant be covered/ blocked by metal. i mounted ontop of the metal and its only blocked by the window and the plastic. some people mount them inside the side mirror, or under the front dash. its not a line of sight thing, its a uninterfered radio signal.
Old Jun 19, 2006 | 10:16 AM
Bxscig's Avatar
I gotta try that then, thanks!
Old Jun 19, 2006 | 07:37 PM
c0v3rr1d3's Avatar
thx for those pics bxscig, i just rewired my xmradio. Took the antenna off the truck so it stops scratching it as it slides around even though its magnetic, it doesn't stick well when waxed. I just drilled a hole through the plastic to snake the wire through then double sided taped the xm antenna over the hole in front of the third brake light.
Now i don't loose signal either when the trunk is open. Thx dude
Old Jun 19, 2006 | 09:02 PM
Bxscig's Avatar
lol you are welcome, I dont know why I didnt think of it sooner.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
08KBP_VA
Oct 22, 2019 01:55 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
rhdune16
Sep 28, 2015 11:31 AM
