my fog light, side marker and black headlights
i just did the headlights last night and i did the side markers and fog light like a couple weeks ago. tell me if i need to fix anything. ill post more pics later
thanks i was planning on cutting those tabs on the side skirts but i was gonna have a shop do it or something so it will look better than me just cutting it. i left the orange reflector thingy in the head light orange so it matches my side markers. and will that megiars headlight kit work? or will i have to sand it down?
I'm sure it'll look great, if it looks good on TW or WDP then it'll look good on any car with color. The only car it might not look good on is NBP because then it'd have to much dark and not enough contrast, but with any colored car, the contrast will look great.
Was too tired and had homework and a quiz and the the bulls game was on and I was low on gas haha. You get any pics? My friend said that there were some tight cars.
And try the megs kit or you can try to redo the wetsand again with the rubbing compound.
if i decided to wet sand it again all i need is the rubbing compound right i dont need anything else?
I also needa wetsand my other set of headlights too soo maybe we can just chip in together and try to do that together.
well yesterday i bought te megs headlight kit thingy and it comes with a bottle of that plastx and a cloth and a buff ball thingy. i also bought some applyer pads cause i dont got a drill to use the ball on. i also have some 1000grit wet sand paper. im thinking about going to return the megs headlight kit and just buy a bottle of plastx and some rubbing compound
1st. 1000 grit - 10 mins wetsanding. make sure to keep it wet.
2nd. 1500 grit- 10 minutes wet sanding
3rd. 2000 grit- 20 minutes wet sanding
(after the sanding you wont be able to see through the light at all, so dont worry)
4th. 3M rubbing compound (rub it in hard, or use a buffer)
5th. Meg's Polish
And wax it up after if you have some wax handy.
5th. Meg's Polish
looks good man..i like the side marker..i tried blacking out my lights this past friday..epic failure..put them in the oven and could not for the life of me pry them apart..ended up ripping my fingernail half off too..lol..i think leaving the orange looks good with the sidemarkers too
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
