LED Dash and Puddle Lamps
Finnaly got around to doing a couple this past weekend.
Converted the dash and a few switches to LED using the new bulbs over at
http://autolumination.com/74.htm for the gauges and the type a neo wedge bulbs for the switches. Used all bright whites, and used blue for the status inidicator on the fog light switch and cruise switch.
Not that bad illumination for plug and play.
Also got around to installing red puddle lamps. Did these in red instead of white since it goes with the Red Led lamps i have in my JDM spoiler. I have these hooked up to the dome light circuit so they turn on and dim just like the interior lights.
Quick video
Quick video
Originally Posted by WillrunifChased
Those LED's weren't bright enough for me, they always seem to turn out well in pictures though.
Looks good man, I have been wanting to do both of those things for a while now.
Originally Posted by 02type-s
What would you reccommend?
For the dash. Yes they are definatly not as bright as the custom job ontarioTL does. But for someone who doesn't have the time,or the know how to do it, this is a simple plug and play. I didn't rub out any filters just used bright whites to give the blue effect. Since i dd my car i can't be without a guage cluster for the time it would take me to do the led dash the way ontairoTL did. So for now these are the next best thing. There is really no hot spotting in person, and i'll try to see if i can get a more truer representation of the brightness with my camera.
For the puddle lamps, yes they are jlevis, for 25 bucks i couldn't pass it up since i've been wanting to do them. I sorta followed how one the members on the tsx fourm did his. I used pvc pipe to house each puddle lamp. I then decided to protect them even more by cutting out some covers out of lexan so nothing will get kicked up into the puddle lamp from the road. Then i secured each one down with epoxy after i drilled out the holes in the side skirts. Then i just ran the wires through the car, instead of all the way around the car like the person did with the tsx. I just ran them up under the back seat and then a simple 2 wire connection at the passenger side fuse box makes them work they way they do.
slick -- yeah idid the same but the way i had them spaced on the skirt i needed to add lengths of wire between each lamp -- so much work lol. 2 of my passengers sides are out now -- maybe a bad connection somwhere since it flutters.
Are the dash leds at least brighter than stock?
Originally Posted by InspireUA5
Nice
Did you drill holes on your side skirts for puddle lights?
where did you get them?
Yes i had to drill holes in the side skirts of the puddle lights since i didn't want them hanging from the bottom. I got them from http://www.jlevistreetwerks.com
Looks Nice! Great Job.
I too am wondering what you got for the bulbs.
I recently did my own and got plain #74 bulbs and have a lot of hot spots and dead spots.
Again, Looks Great!
EDIT: are they the Tri Power?
http://superlumination.com/images/au..._3led_w_wm.jpg
Again, Looks Great!
Yes sorry i didn't specify they are the tri-power ones, the first ones found at
i got the super-white version
Again, Looks Great!
Again, Looks Great!
:( Harminder Is Lost In
thanks to c0v3rr1d3, i finally got my buttons matching my gauge LOOKS CLEAN. Is their a way i can get some leds liek this to match for the ac/heater unit? I have navi so its that little one under teh screen, my temp button one is out.
Originally Posted by seanranger3
did ontairoTL ever made a DIY
I could never find one, the long thread he had, it looks like stupid people pissed him off enough to never have released a diy.
