How all TL's should sit
Old 02-07-2008, 05:38 PM
`ill*tl's Avatar
Talking How all TL's should sit
..as the title says. I'll get some better shots of my new setup tomorrow.
Old 02-07-2008, 05:43 PM
Never Summer's Avatar
Just throw some 19's on there and that'll look great.
Old 02-07-2008, 05:47 PM
`ill*tl's Avatar
.. had some 19's on, but took them off b/c I'm changing my wheel setup as well.
Old 02-07-2008, 05:51 PM
Well in that case send them to me.
Old 02-07-2008, 06:14 PM
AZP-TL's Avatar
If mine was dropped that low I'd scrape on speed bumps and dips around here.
Old 02-07-2008, 06:22 PM
Just chillen..
FL3.2TL's Avatar
Still too high...
Old 02-07-2008, 06:33 PM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
What do the camber readings look like??
You can buy home use guage for cheap as a ~roof incline guage~ at hardware stores
Simply place against the center of the wheel and it tells you the degrees off vertical you are
Also measure from the center of the wheel to the fender edge- side to side differance will off weight the car and throw more camber at the heavy side.
Do this front side to side and same for the rear clearance.
The rear camber is most affected by a drop in height. Neg 1 degree is max spec limit for most of us (check your specs) so up to about neg 1.5 and you wont cook the tires
Beyond that, and for tuck the wheels inside the fender drop crowd- rear camber kits are in order.
At least you can match the camber front to rear that way and equally wear the tires
Old 02-07-2008, 08:52 PM
`ill*tl's Avatar
Nonsense.. low and slow is the only way to go.
Originally Posted by FL3.2TL
Still too high...
Yup, you can't tell from the pic. but I have MAD camber in the rear. I already have the SPC rear camber kit, and am just waiting for a buddy of mine to mail me my wheel lock so I can get the kit installed.
Old 02-07-2008, 09:19 PM
Volks FTW!!!
LeeDan00's Avatar
now that is CLEAN!! i would slam mine that low but i'd be afraid to scrape on everything. your car looks really clean though. what are you lowered on btw?
Old 02-07-2008, 09:30 PM
NBP
ABCTypeS's Avatar
wow super nice whip
Old 02-07-2008, 10:52 PM
T-Swzy
Razzi's Avatar
i had the same height and my front lip scraped on EVERYTHING
Old 02-07-2008, 11:11 PM
WDPTLS's Avatar
i want my car to look exactly like that!!! im getting there, slowly but surely, your car is pure sex bro, nice work, wdp ftw!
Old 02-08-2008, 01:13 AM
eleventure's Avatar
nice. Thats about the same height as mine
Old 02-08-2008, 01:19 AM
LIST/RAMEN/WING MAHSTA 짱
princelybug's Avatar
Nice drop, nice ride!
Old 02-08-2008, 03:05 AM
AZP-TL's Avatar
I would love to drop it but i'd rather not ruin my lip kit. The front is already scraped and paint peeling and I'm at stock height!! Damn huge dips between the road and sidewalks.
Old 02-10-2008, 11:53 AM
`ill*tl's Avatar
Thanks for all the compliments and to the person that asked what kind of suspension I was on, I'm on Ksports.
Old 02-10-2008, 12:18 PM
bringin lead
FirePR2002's Avatar
^^X2. Can you post a pic from the rear so we can see it before you install the kit? While you're at it, might as well do a before and after - if you don't mind?
Old 02-10-2008, 01:13 PM
Kang Ho
SupaRookie's Avatar
yea yea, whatever Brian. Car looks super clean man. We should find some other 2nd gen wdp and take pictures.
Old 02-10-2008, 02:12 PM
Lamborghini Aventador FTW
AMGala's Avatar
Nice WDP!
Old 02-10-2008, 02:13 PM
ഥഎണഡഏ Fellas Inc.
Malayalee King's Avatar
check out this one, crank them down lower: http://img.photobucket.com/albums/v3...ammedTypeS.jpg
Old 02-10-2008, 06:03 PM
Kang Ho
SupaRookie's Avatar
I dont think you can make it your daily driver.
Old 02-10-2008, 06:13 PM
Autoworks's Avatar
Hows the ride quality of the K Sports?
Old 02-11-2008, 02:30 AM
Feenin on some 20's
ILLustriousUA6's Avatar
x2
Old 02-11-2008, 01:04 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
I want to see picks of your engine cover installed
Old 02-13-2008, 12:10 PM
ഥഎണഡഏ Fellas Inc.
lol he had them in his backseat when he came over because the screw-pin on the left wasn't making it through when the far left push-pin and far right screw-pin were latched.
brain's time spent: 45 minutes
kiran's time spent: 4 mins...bend the rail that it screws into up
Old 02-13-2008, 02:08 PM
fsttyms1's Avatar
Old 02-13-2008, 03:04 PM
`ill*tl's Avatar
lol Kiran... hush..
Thanks Trung, yah.. we should definitely find some 2G WDP TL's and have a photoshoot like Donald.
Autowork's: The Ksports are a bit on the firm side.. still getting used to bouncing around but overall, its not too bad as some ppl say. The fronts are set all the way to the softest and the rears are set to mid... the softest damper setting is pretty soft, but not as soft as the TEIN SS's would be.
Old 02-13-2008, 04:23 PM
ഥഎണഡഏ Fellas Inc.
did u get wheel lock
Old 02-13-2008, 05:47 PM
`ill*tl's Avatar
Nope, nothing but junk mail. I'll give it till' tomorrow..
Old 02-13-2008, 11:17 PM
Feenin on some 20's
lol Kiran... hush..
NEVER!
Old 02-14-2008, 12:27 AM
Kang Ho
SupaRookie's Avatar
psh...please. We should do a local shoot sometimes. Was waiting for Kiran to get his shit together, but now it looks like that will be in summer...ahaha.
Old 02-15-2008, 04:17 AM
2000 Acura 3.2 TL (185K+)
Toon_703's Avatar
im diggin it I also like when the car is slammed in the front and sittin a LITTLE higher in the back.
Old 02-15-2008, 05:07 PM
jimmiexiong's Avatar
what suspension set up are you using ! thats one sweet azz tl! i have exact one! yet to drop, thinking of going with tein ss!
Old 02-15-2008, 05:38 PM
Max Boost's Avatar
what kind of 19"wheels are those?
Old 02-16-2008, 01:30 AM
`ill*tl's Avatar
jimmiexiong : Scroll up a couple posts and you'll find your answer. This is a forum, you'll need to learn to read ppl's posts. I'm on Ksports.
Max Boost : 19x7.5" ADR Battle Axe (Gunmetal) w/Machined Lip ..looked a bit odd on my car, so I'm going w/a different set of wheels.
Old 02-16-2008, 12:36 PM
Max Boost's Avatar
Ya i know its a forum, since i didn't see it on the first page a rather ask.. thats just me.
Old 02-17-2008, 12:04 AM
`ill*tl's Avatar
lol, I wasn't talking to you..
Old 02-20-2008, 12:02 AM
02TL-S
caree1907's Avatar
Thumbs up wow
That's Hot!! How bad do you rub?! I have 19" on my TL-S and I was rubbing hard, and I still rubbed alittle bit after I had my fenders rolled by the pros.
Old 02-23-2008, 12:08 AM
caligirl2k's Avatar
Yeah thats is hot I love the rear
Old 02-24-2008, 10:29 PM
Feenin on some 20's
dam brian, u gotta move to the bay area man... are u planning on getting any wheels?
Quick Reply: How all TL's should sit
